55EC930V Help please
  • jram
    • Aug 2019
    • 18
    • United Kingdom
    Ok, I have downloaded the SMPS guide.
    The symptoms are that the LG symbol lights and flickers when the black power button on the back of the unit is pressed and also when the remote power button is pressed. The TV does not power on.
    AC (240V) is present ath the sck100? where the power arrives on the main board. All fuses are intact and all apart from the one by the main socket have 120V.
    Power Supply Board Low Voltage Test 1 yields the following:
    3.5V at pins 3 and 5 of P201.
    I disconnected P2300 ribbon cable and added R110 across pins 1&3 or 1&5 but this yields no click and no 12v or 24v power when AC is supplied.
    So either the relay is bad or ??? Any guidance greatly appreciated
    • 12167
    • U.S.
    Re: 55EC930V Help please
    How bout some good pictures of all the boards and one of the whole back including all the boards, and a up close picture of the P2300 and any legend/map of the expected voltages.
    • R_J
      • 9535
      Have you checked all the fuses in the secondary? F501 should be good, its for the standby circuit.
      It looks like optocoupler IC503 drives Q501 to drive the relay so see if you have any voltage on the cold side of the optocoupler. To check the voltage on the output side of the opto you need to use the HOT ground, BD103 (-) or one of the main caps (-) lead
      You can also check if you have voltage across C507, this is the supply voltage for the relay
      [quoye]I disconnected P2300 ribbon cable and added R110 across pins 1&3 or 1&5 [/quote] What is R110? you need to use a 1KΩ resistor to jump between 3.5V (J100) and PWR-ON (J94)
      • jram
        • Aug 2019
        • 18
        • United Kingdom
        Ok, Thanks for the feedback guys,
        @nomoresonys - I'll attach the photos below.
        @R_J - The fuses are all good. On checking the voltage to the Opto with the link across pins 1&3, I see a fluctuating voltage of 1V +- 0.1v which is not good (I expected 3.55V - correct?).
        With the link removed, I see a steady 3.55V at the terminals on IC503 (on the low side)
          • 12167
          • U.S.
          Recheck P201, do it just like #3 in my signature below.
          • jram
            • Aug 2019
            • 18
            • United Kingdom
            @nomoresonys Thank you, I will. Unfortunately have to go away for some days due to family illness - will catch up next week. Thanks for your help
              • 12167
              • U.S.
              Glad to help, best wishes, hope they have a speedy recovery.
              • jram
                • Aug 2019
                • 18
                • United Kingdom
                OK - I'm back! Many thanks for your good wishes
                I made sure everything was plugged in but inverted the power board to gain access to P201 pins from the rear. I attach a picture of the pins and the legend above
                The voltages are as follows:
                System power on but in standby
                0 0
                0 0
                0 0
                0 0
                0 0
                0 0
                3.55 3.55
                0 3.55
                1.9mV 0
                I then pressed the remote power button once. The LG led dimmed and recovered.
                the following (same) voltages were measured
                0 0
                0 0
                0 0
                0 0
                0 0
                0 0
                3.55 3.55
                0 3.55
                1.9mV 0
                • R_J
                  • 9535
                  Did you meaure the voltages WHILE pushing the power button, or just push the power button, and after the led dimmed/recovered, measured the voltages again?
                  Check the PWR-ON pin while pressing the power button
                  • jram
                    • Aug 2019
                    • 18
                    • United Kingdom
                    Thanks for your patience - sorry
                    OK with the PWR button held ON
                    0 0
                    0-5mV 2-40mV*
                    0-35mV* 2-40mV*
                    0 0
                    0-5mV* 1-5mV*
                    0 0
                    3.55V 3.55V
                    0 3.55V
                    1.9 - 50mV 0-?? Volts - oscillates high enough to get the meter to switch scales and then cuts off to zero and restarts - period about 2 seconds
                    *These values oscillate up and down with a period of about 2-3 seconds
                    Thank you.
                    • Diah
                      • Feb 2013
                      • 6364
                      this is wrong work. your MB and T-CON driver boards should disconnected from PSU when you like to trace the 12 & 24 Volts on PSU.
                      Never..NEVER connect the both mentioned board to PSU if you are dont have clear stable 12 & 24 V on PSU.
                      yours photo https://www.badcaps.net/forum/attach...2&d=1566988083 solder out the both driver IC near to LB501 502 0n the back side of PSU. you will find the issue there if one of them cracked out.
                      • jram
                        • Aug 2019
                        • 18
                        • United Kingdom
                        This is the recommended technique from @nomoresonys.
                        For your technique, please may I ask you to answer with details of your technique, test points used and any other information available?
                        Many thanks
                          • 12167
                          • U.S.
                          Ideally you leave the board screwed down and use skinny probes or back-probes to measure the voltages, I use stripped down bread ties on occasion.
                          • jram
                            • Aug 2019
                            • 18
                            • United Kingdom
                            @nomoresonys, my results at #10. Had to flip the board over but can't see it would make much difference since it was still connected to the other boards per the instructions.
                            Seems there is a problem getting the 12 and 24V to start/hold on
                            • Diah
                              • Feb 2013
                              • 6364
                              Many thanks
                              there are no specific technique required.. all roads drive you to ROM.. only notice the following:
                              you have downloaded SMPS guide as u mentioned at your first post.
                              point one as i mentioned keep the MB and T-CON driver board out,, disconnected from PSU. solder pin 3 which are stand by voltage to pin power ON this will make the relay click look like MB connected and send command signal to power on the PSU. with this state trace the 12 and 24 volts..
                              check the 2 driver ic which i wrote at my pervious post. i found many LG OLED one of these driver cracked out.
                              • jram
                                • Aug 2019
                                • 18
                                • United Kingdom
                                Thank you - I'll get to it
                                • jram
                                  • Aug 2019
                                  • 18
                                  • United Kingdom
                                  With pin 3 connected to to pin 1, the pin 3 voltage oscillates at about 1-2Hz between 1-2.6 V. There is no click, there is no 12V or 24V measurable. Pretty much the same results as my 1st post.
                                  Anyone got a circuit diagram?
                                  • Diah
                                    • Feb 2013
                                    • 6364
                                    i think you had wrong contact.
                                    you should connect 3.5V to the pin PWR_on not DRV_on
                                    PWR_ON = power on ( Supplying 12 24 V to MB ) Relay Click .... this one we like to trace first.
                                    DRV_ON = driver on ( supplying 24 volts to T-CON driver this will work only if you have relay click and 12 24 V present by step (PWR_ON )
                                    • R_J
                                      • 9535
                                      check if you have voltage across C507, this is the supply voltage for the relay and is also the feed back voltage for the standby circuit
                                      If you are working from the top of the board, use J50 (hot ground) and and check the voltage on D505 cathode.
                                      The relay needs to operate before you will get 12v or 24v The standby voltage should not drop when you short pin 1&3
                                      I suspect you have a bad cap in the standby circuit, C503,C507,C504
                                      In the original post you say you measure 120v at the fuses, is that measured to chassis ground or from hot ground?
                                      To measure the voltage on F101 and F102 you need to have your meter on DCV and the ground needs to be on C621 negative or use the negative of BD101
                                      • Diah
                                        • Feb 2013
                                        • 6364
                                        120 V on Fuses as he report are very low.
                                        you can disconnect one side only of Fuses F101 and F102 to remove the load to check the relay will click or not..
                                        you can also take out the relay and open the cover case and check it of function out side the board
                                        • jm1234
                                          9V relay temperature 40C
                                          by jm1234
                                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                          05-09-2024, 03:03 AM
                                        • edugimeno
                                          Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                          by edugimeno
                                          Hi everyone!
                                          I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                          I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                          This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                          To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                          I respected the polarity, positive to cathode of protecting diode
                                          So provided all...
                                          04-18-2024, 01:15 PM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                        • rhinomods
                                          LG 55ec9300-UA No Picture, No Sound, no 5vUSB
                                          by rhinomods
                                          Howdy,
                                          I have gone through the forums and tried a bunch of things that others had posted. I am hoping some one can point me into the right direction.
                                          Original symptoms.
                                          press the power button you can hear the relay click.
                                          The LG logo illuminates white for a moment then fades out.
                                          Behind the back cover.
                                          when Power button is pressed the red LED on the Main/Media board stays illuminated.
                                          You can not turn the tv off with the power button. when using IR remote You hear the relay click OFF and the Red LED is no longer lit.
                                          07-27-2021, 08:02 PM
                                          Samsung LN46b530p7f – relay clicks and backlight cycling, sound OK
                                          by momaka
                                          I got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
                                          Problem:
                                          Backlight cycles On and Off.
                                          Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark....
                                          01-17-2019, 11:23 PM
