Sony KD-55s8505c restart loop
  • atef33
    • Feb 2013
    • 8
    • italy
    Hello , please i need e firmware to my sony tv 4k model number :KD-55S8505C to use for usb to update the software because tv is dead , thnks a lot
    • lotas
      • Jan 2016
      • 4753
      • Russia
      If your TV is broken, how do you fix it using usb software? Is it in update mode (the LEDs blink one after the other)?
      • davidebeatrici
        Sony M851 MBX-217 no POST and restart loop
        by davidebeatrici
        Before proceeding with a component level repair, the usual troubleshooting process was followed:
        1. Disassemble and unplug everything except the power connector.
        2. Replace RAM.
        3. Replace CPU.
        4. Rewrite BIOS.
        Unfortunately the board was still stuck with a 0.75A power consumption at 19V.
        After reflowing both GPU and north bridge in one shot (it can't hurt) there was an instant improvement with a constant 1.75A power consumption, but I immediately noticed smoke and the typical smell coming from the GPU area.
        I thought to myself "Well,...
        07-03-2025, 04:19 PM
      • justin35
        Sony bravia kdl-43w755c - boot loop
        by justin35
        i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
        from what i read online it looks to be an emmc issue…
        i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
        i took out the board and say an samsung 16gb emmc
        i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
        i could try to put one instead of the 16gb one, but will it work?
        where do i get the software from?
        any help will be much appreciated!...
        03-06-2024, 12:26 PM
      • Takeatry
        Yet another Samsung QLED Boot Loop
        by Takeatry
        Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
        10-04-2024, 02:57 PM
      • rvh
        Repairing a Sony KD-49X8309 tv (android boot loop)
        by rvh
        I got a Sony led tv, that's stuck in a boot loop. It won't go any further the android screen and won't turn on further. The indicator light turns up white, and then it comes in a boot loop
        It seems, that all of the Sony tv of this X-range will end with these problems after 2-3 years or so.
        Television
        Sony KD-49X8309c
        Main board
        1-894-595-12
        Y210B300c
        Sony BMFW
        Panel:
        SYV4941
        The problem is the mainboard. That's confirmed by Sony.
        After some googling, i came...
        02-26-2020, 05:53 PM
      • Carlos#2003%
        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
        by Carlos#2003%
        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
        02-15-2024, 07:52 PM
