Westinghouse wg55ur4100 no response
  • microvibe
    • Mar 2013
    • 275
    • canada
    Re: Westinghouse wg55ur4100 no response
    Cv838h-b-11-170818 is the number
    • CapLeaker
      Leaking Member
      • 8352
      That is the main board number. I am looking for the part number.
      • microvibe
        • Mar 2013
        • 275
        • canada
        These are only numbers i find on board
          • 12332
          • U.S.
          Wonder if this is a match, the numbers seem to match up: https://www.ebay.com/itm/WESTINGHOUS...ty!43616!US!-1
          • CapLeaker
            Leaking Member
            • 8352
            in that link there is this number W18054-SY
            Is there something like that on your board or TV?
            • test.testary
              • Jul 2023
              • 5
              my scenario is a little different, same exact westinghouse model.
              After pressing power button to turn on, green LED turned off, with the use of a flashlight i can picture, also i remember i connected a fire TV and played a video on YouTube and there was sound. so I am assuming mainboard is fine, T-CON is fine based on the below readings as well.
              Those are the readings I got with all main board cables hooked
              Cn201
              V12= 12.3v
              V12= 12.3v
              Gnd
              Gnd
              Gnd
              V5= 5.1v
              V5= 5.1v
              Stb= 5.1v
              Ps-on= 3.1v
              V5= 5.1v
              V5= 5.1v
              Cn202
              V24= 24.6v
              V24= 24.6v
              Gnd
              Gnd
              - I got crazy readings here which i couldn't interpret:
              Led1+ 155.1v diff with Led1-
              Led1+ 216v diff with TV metal body (GND)
              Led1- 0v
              Led2- 0v
              Led1- 0v
              Cn206
              Bk= 5.05v
              Adj= 2.898v
              Gnd
              Gnd
              What should be the normal readings on Led1+,- and Led2+,- on a working TV of that exact model???
              What else should I test to know if it's the LED strips malfunctioning or something still wrong with the power supply itself please?
              Thanks for any help
              • R_J
                • 9627
                The LED output voltage is likely around 110 ~ 130vdc @ 600ma. You have open led's in the string causing the voltage to read high and cause the protection to cut in.
                • test.testary
                  • Jul 2023
                  • 5
                  Thanks a lot. I finally got a the tester from Amazon and got to open the TV. First just with tester, one half of the TV did not show any light with the tester and the other half showed very faint light (probably because the tester current is max 30mA or something). Then when I opened the TV and removed the screen and filters, found 2 out of the 10 strings were not functioning well. 1 completely dead and the other has just 1 worked LED out of the 5 in that string. LED string part number is 3P55TA004-A2. Gotta find out where to get replacement for those two malfunctioning strings.
                    • 12332
                    • U.S.
                    #29
                    Wonder how microvibe came out, kind of shitty not to give any followup.
                    • test.testary
                      • Jul 2023
                      • 5
                      Hey again everyone
                      seems 3P55TA004-A2 is almost impossible to find.
                      would another part number work? say 3P55TA004-A0 which seems to be more available
                      • tech9pc
                        • Sep 2021
                        • 50
                        That's correct 3P55TA004-A2 and 3P55TA004-A0 both will work. I have had same tv sitting here for over a year and have not got around to getting leds.
                        Westinghouse WG55UR4100 TV is same as Element E4STA5517
                        • test.testary
                          • Jul 2023
                          • 5
                          tech9pc,
                          I sent the same question to shopjimmy and they said no both part numbers are not compatible and to keep looking for A4.
                          So I'd rather hear it from someone who's tried it, did 3P55TA004-A0 work well on your westinghouse WG55UR4100​ TV? did you mix A0 & A4 without problems?
                          • tech9pc
                            • Sep 2021
                            • 50
                            No I never tried it yet test.testary ... but thats my plan since the strips are obselete/discontinued and mostly all gone. The WG55UR4100 I have I used a bunch of the strips to fix another identical one. So now going to just get the 3P55TA004-A0 and use them to get this one back up and running when I get to it.
                            They are good tv's still and have nice picture even though they are older 2017 or so models. Still actually better than most the garbage they are pushing now.
                            WG55UR4100 uses 10 strips (5 x 3 volt leds on each strip) 3P55TA004-A2
                            WG55UX4100 uses 10 strips (5 x 3 volt leds on each strip) 3P55TA004-A0 - both tv's are pretty much identical except UX4100 model is contrast ratio 4000 : 1 ... and UR4100 3000 : 1
                            both strips are practically identical in length and led placement ... even the connectors are same
                            Here are some links and some good photos from a foreign website that shows clearly the 3P55TA004-A2 and 3P55TA004-A0 led strips right down to even having the same connectors.
                            3P55TA004-A2 - https://electronicamorelos.com/index...oduct_id=30963
                            3P55TA004-A0 - https://electronicamorelos.com/index...oduct_id=30958
                            • neilc6
                              Factory Reset Westinghouse WG55UR4100 Android TV
                              by neilc6
                              I repaired the backlights on this model (symptom flash of backlights, repaired seven bad, part#3P55TA004-A2 new strips available at Shopjimmy) and now the TV is stuck on the home screen. I can only turn the TV on with the remote and no buttons work once booted on the home screen. Only the TV buttons volume -/+ and on/off work. There is no physical menu or input buttons.
                              I think a factory reset will clear it but not a lot of options. Tried the Sony Android methods of holding down the on/off button while plugging it it and holding down vol- with power on/off....
                              05-26-2021, 03:26 PM
                            • alro7779
                              Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
                              by alro7779
                              Hello, guys!
                              I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
                              Alex....
                              10-03-2025, 05:49 PM
                              HP Elite 8300 computer completely locked no response from key board or mouse
                              by sam_sam_sam
                              Dose anyone know what would cause this issue because I do not understand what is going on
                              The setup is the hard drive is set to never turn off
                              The video set to not turn off
                              Supposedly it setup is not to power down at all but something is not working correctly
                              I have three of these computers and the other two work correctly with this setup
                              The video is on the screen but the keyboard has no lights on and no response the mouse light is on but no response to movement
                              The power button does not respond correctly either because if...
                              06-19-2022, 07:49 AM
                            • rumpumpel1
                              Lenovo L480 NM-B461: strange power delivery response
                              by rumpumpel1
                              I have a L480 board with a working USB-C port and a non-working docking port that only runs on 5V. I have replaced the TB-Bios but to no avail. Both ports show 0,6V in diode mode. My Kingst Logic Analyzer showed the following strange response.
                              The charger offers correctly 4 voltages:
                              0.8781038000,Header,(8589951393),DataObject:4 Source V3 DFP Source_Capabilities
                              0.8781686000,PayLoad[0],(168923436),V:5V Imax:3A
                              0.8782978000,PayLoad[1],(1233196),V:9V Imax:3A
                              0.8784272000,PayLoad[2],(1356076),V:15V Imax:3A
                              0.8785566000,PayLoad[3],(1458501),V:20V Imax:3.25A​...
                              07-23-2024, 06:17 AM
                            • Nicktronic
                              Westinghouse W55UW4620 No Video
                              by Nicktronic
                              Ok, so I know I know, it's a Westinghouse....lol It's got the backlights but no video. Likely the panel, but I'd like to take some measurements on the buffer board with help from you experts to confirm. See the attached pictures. In pic #1, there's a nice pin reference to use to take some measurements. The large IC in pic #7 gets up to 60degC when the TV is on.
                              So, backlights, no video, go! 🙂...
                              06-03-2024, 03:21 PM
