How to know which part to order
  • Fixing222
    • May 2017
    • 67
    So I replaced all parts suspected of causing a issue except the powerboard but costs have gotten high. When I type my model number in for my TV the boards are expensive.
    But when I type 17IPS20 R9 which is the board I have the boards look exactly the Same except they might have one less resistor at one point on the board some one less capacitor etc.
    When I look up the schematic for 17IPS20 surley there all the same.
    Might this for instance work
    https://rover.ebay.com/rover/0/0/0?m...2F223605328835
    Or this https://rover.ebay.com/rover/0/0/0?m...2F223605326085
    Picture of my board attached just trying to find out what to order
    For Panasonic TX-48CX400b
  • Diah
    • Feb 2013
    • 6397
    Re: How to know which part to order
    you need to consider only on yours TV size not model
    17IPS20 R9 are vestel and can found at many brands of TV. but should the size of the TV correct other wise your damage will be huge
      https://www.badcaps.net/forum/attach...7&d=1565478273
      Printed Black silkscreen '17IPS20' is the blank PCB number that can be used to make many PCBA's (Printed Circuit Board Assembly), you need to go by the barcode sticker number, that is the PCBA number of the power supply for your TV model.
      Vetsel schematic is the master circuit that has ALL the components for making the PCB, but the PCBA for the required TV model will not have all the components as shown in the schematic installed into the board.
      So why do you think you have bad power supply.
      • Diah
        • Feb 2013
        • 6397
        consideration on TV size only related to the back light. if the size are deferent back light are deferent too.. other supplement voltage will be same and passed
        • Fixing222
          • May 2017
          • 67
          Ah ok thank you for explaining, that is very helpful and I can look for the right thing now.
          I was looking for one as I have backlight when I turn on TV and sound after speaking to someone experienced somewhat they recommended a mainboard and if that didn't work it was most likely the Power supply (I ordered a T-con from what I heard about this issue and pretty cheap but wasnt that) as I also have 13/14 blinks
          As shown here https://vimeo.com/352833830
          Which indicates a issue from what I hear in communication between boards (panasonic error code). So I was told the only thing left that could be so hopefully it's causing the issue.
            Related to this thread?
            https://www.badcaps.net/forum/showthread.php?t=78472
            • Fixing222
              • May 2017
              • 67
              Yes
              • Diah
                • Feb 2013
                • 6397
                https://www.badcaps.net/forum/showthread.php?t=78596
                last 2 page
                • Fixing222
                  • May 2017
                  • 67
                  So the power output to the mainboard and the LEDs which are the only things that matter are highly likely to be the same and ok if the screen size is the same?
                  • Diah
                    • Feb 2013
                    • 6397
                    yes
                    i think you don't need to invest any more right now... i put link on post same issue and poster said it solved.. take look and any things you need you can ask over here
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • Cvrado
                      Led TV Board Replacement, same part number and model, different size
                      by Cvrado
                      Hello my friends!
                      I have a question that I think you can answer and help me with!
                      I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
                      So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
                      My concern is that the board won't draw enough voltage to the bac...
                      03-02-2024, 05:05 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • PizzaMan
                      Macbook Air A2681 logic board, find this part
                      by PizzaMan
                      I am trying to find this part on the logic board. See pictures below. It might be CR812, not sure. Any help would be appreciated. And where could I find the part?
                      05-24-2025, 12:34 PM
