60pb660v circuit
  • thuss
    • Jul 2012
    • 321
    60pb660v circuit
    Hi
    My mate finally decided to change an ic on my 60pb660v ysus board. Unfortunately one of the pads in the process has been removed .
    I was wondering can anyone tell me where on the attached photo the ic highlighted in the yellow boxes- leg numbered three connects to even the solder below the pad has been removed?
    thanks in advance.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: 60pb660v circuit
    That pad is not used. Look up the datasheet for that ic and it will probably say n.c.(no connection).
    • CapLeaker
      Leaking Member
      • 8297
      just run a thin piece of wire from the through hole to the lC's leg. Put some conformal coating over it and be done with it.
      • thuss
        • Jul 2012
        • 321
        Sorry I don't know what you mean by the through hole- can't I just leave it floating in the air
        tvtimmy you are right it is n.c - not connected
        thanks to you both for the advice
        • CapLeaker
          Leaking Member
          • 8297
          look at the second picture. Isn't the leg in question (pin 3) having a trace to a small solder point? Look where it goes on the other side of the PCB.
          • thuss
            • Jul 2012
            • 321
            theres a jumper on the other side which leg 4 is connected to but nothing else- I think its time forthis tv to to a shop or into the bin - will try one last thread tho thanks
            • CapLeaker
              Leaking Member
              • 8297
              what is printed on the IC?
              • thuss
                • Jul 2012
                • 321
                The original ic was 200D6 which I replaced with an ic with part number 200D1.
                The full name is NCP1200D60.
                • CapLeaker
                  Leaking Member
                  • 8297
                  So pin 3 is the current sense pin. You better hook that one up. Pin 7 has no connection. You can leave that one off.
                  • thuss
                    • Jul 2012
                    • 321
                    Sorry my mistake- I meant pin 7 (n.c not connected) - thank you ( my numbering on the attached photo didn't the data sheet sorry)
                    Once again thanks for the help I really appreciate it
                    • R_J
                      • 9583
                      The ic's pin#1 are marked with a ►
                      • thuss
                        • Jul 2012
                        • 321
                        The ncp1200D60 chips that my mate got haven't got any arrows/dots on, he assumed that the solid white line (read in conjunction with the writing) indicated where pin 1 was
                        • R_J
                          • 9583
                          The mark ► I refered to is on the pc board. The soic-8 ic should have a small dot for pin 1 but will also have the pin1 edge slightly tapered (see pdf)
                          • Astonished
                            Fixing the Charge Circuit of the Batteries of the DC Motor
                            by Astonished
                            Hi friends of electronics
                            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                            Please help me fix this circuit.
                            (the datasheet of the IC: https://pdf.datasheet.live/28...
                            01-28-2025, 06:24 AM
                          • Tarot Superstars
                            Short Circuit tester
                            by Tarot Superstars
                            Hello.
                            I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                            The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                            Link
                            The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                            https://www.youtube.com/watch?v=0eixDdCpiO4
                            My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                            09-25-2023, 09:11 AM
                          • Alimash
                            op amp circuit function?
                            by Alimash
                            I am repairing a ups which doesn't turn on ,it has the following ICs:
                            SG3525 used to drive inverter mosfets.
                            couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                            A LM358 and TL074 for control mechanism and of course the uController.
                            The SG3525 is shutting down every time the ups is turned on.
                            I want your help to know the function of LM358 and TL074 in the system.
                            I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                            07-31-2025, 07:45 AM
                          • M1NEBLANK SHOW
                            MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                            by M1NEBLANK SHOW
                            Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                            (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                            Schematic and Boardview here
                            04-04-2025, 03:57 PM
                          • прямо
                            Viper22A 5VSB circuit
                            by прямо
                            So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                            In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                            01-13-2024, 07:05 PM
