50PA4500 safety
  • Jkirk3279@gmail.com
    • Aug 2019
    50PA4500 safety
    I have the back off the TV, the red light is constantly clicking...
    I was wondering if the clicking relay was on the Power board, and leaned closer.
    I got a healthy shock when I tapped the central heatsink bar.
    About sixty volts AC.
    Just curious if this is normal, or if stray voltage means the board is hosed.
    Thanks.
    • 31083
    Re: 50PA4500 safety
    heatsinks are often live in some way, because they are in contact with metal components.
    • R_J
      • Jun 2012
      • 9553
      Re: 50PA4500 safety
      Yes that is normal, the heatsink is likely connected to hot ground on the primary side of the power supply, and it can sit at about half the a/c line voltage.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8210
        Re: 50PA4500 safety
        that is why you are supposed to be really careful in the hot section of the PSU. Always take measurements first if you are not sure.
        • SLK001
          • May 2014
          • 264
          Re: 50PA4500 safety
          Thanks.
          Yes, it is normal that if you fix broken TVs, you will often receive a healthy shock. You will get used to it.
            • Aug 2019
            Re: 50PA4500 safety
            Oh, of course.
            My blood sugar must have been low, I knew that.
            Thanks.
            I was just worried that more than the cap was bad.
              Re: 50PA4500 safety
              You should at least plug what ever you are working on into the GFCI outlet.
              • Packard93
                • Jul 2016
                • 81
                Re: 50PA4500 safety
                Always use safety when working in tv. It will have two sides on the power supply board hot and cold. HOT SIDE IS AC AND COLD IS DC. OR IT WILL SAY PRIMARY FOR AC AND SECONDARY FOR DC ON THE PCB LOOK FOR WHITE LINE .TV VOLTAGE CAN KILL SO DONT touch the hot and primary on any pcb. There live discharge is about 30 mins but not all capacitors can hold charge even after 30mins .
                • B0r1s
                  Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                  by B0r1s
                  PSU - BN44-00878A
                  Symptoms:
                  The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                  A weak clicking sound was coming from the transformer.
                  Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                  Progress:
                  After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                  01-17-2023, 04:58 PM
                • slimmy182
                  [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                  by slimmy182
                  Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                  I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                  Looking on google I found this:...
                  01-14-2023, 11:55 AM
                • fadi90
                  PILZ PNOZ X4 Safety Relay
                  by fadi90
                  I'm working on repairing a Pilz PNOZ X4 safety relay module. When I opened it up, I found some of the connector pins detached from their pads. I replaced the connector with individual wires, but the issue remains.
                  The module is set to dual-channel mode with manual start. In this mode:
                  • Y36-Y37 and Y1-Y2 are bridged.
                  • 24VDC is applied across A1-A2.
                  • It monitors two emergency circuits (S11→S12 and S11→S52).
                  • When both are closed (24V present on S12 and S52) and the start button is pressed (S33 connected to S34), the NO contacts (13-14, 23-24, 33-34)
                  06-07-2025, 01:21 AM
                • beetle1303
                  Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                  by beetle1303
                  I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                  On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                  01-13-2025, 08:49 PM
                • mikelu53
                  Samsung UN60D8000YF Clicking BN44-0432A
                  by mikelu53
                  I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
                  The set was working then not,then started clicking.
                  Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
                  Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
                  A schematic or suggestion would be great.
                  01-21-2023, 03:14 PM
