Need help with logic board testing on insignia tv
  • Packard93
    • Jul 2016
    • 81
    ok Ive tested every board x and y connected no clicks
    disconnect x and y boards connecting the main board and the logic board click starts . Disconnect logic board with only main connected clicking stops
    So with all these test is it fair to say its the logic board
    having issues with this board once its connected I get the 5 click issues and red power light blinks .
    Service manual says this is testing procedure for the Insignia NS-42P650A11 Im having technical issues . I read somewhere that logic controls the main and power so if logic fails the signal wont reach the power board after the main .
    Last edited by Packard93; 07-25-2019, 10:20 AM. Reason: adding infomation to help give more insight to repairs
    Re: Need help with logic board testing on insignia tv
    You will get a lot more help if you provide the Model number, and good clear pictures and details of what you had test so far, I.E. Voltage readings, resistance testing, etc.
    Right now we have no idea what we are dealing with.
    • Packard93
      • Jul 2016
      • 81
      Not working on lcd panel this plasma.Insignia NS-42P650A11 i see a standby voltage 5.3 volts between main and smps. logic board connected is when I get a series of 5 clicks then after the clicking stops I get solid red light . From what I read this means the power supply is working .
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • cheeky2
        by cheeky2
        05-25-2024, 03:27 AM
