Sharp 70inch led 3blink & 1short
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Sharp 70inch led has 3 blinks and 1 short.....i try force reset vol - ch - it wont do any change the ligth stay lit like if tv is on then after 15 secs goes into 3blinks and 1short....the tvs have lots of commun problems...
    • 12137
    • U.S.
    Re: Sharp 70inch led 3blink & 1short
    What's the full model number?
    • diif
      • Feb 2014
      • 6978
      • England
      Without knowing the model number I can't be 100% but it's "initial communication error" that's either the EEPROM or CPU or the circuitry that powers them.
      • hmendez86
        • Jun 2015
        • 344
        • united states
        Lc-70le745u
          • 12137
          • U.S.
          Check Q7120.
            • 12137
            • U.S.
            With everything hooked up and power on, measure vdc on Q7120, starting from right leg, call furthest right leg pin 1, measure all 4 legs, report voltage readings.
            • diif
              • Feb 2014
              • 6978
              • England
              Yes, it's a CPU communication error.
              Service manual attached.
                • 12137
                • U.S.
                Unplug set, press and hold (on set) volume-down and channel-down and hold them while pluging in the set Will come on with "k" on screen.
                If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter.
                Let set recycle to green and unplug/re-plug in 5 seconds. I see you already tried this, sometimes it takes a few tries.
                • hmendez86
                  • Jun 2015
                  • 344
                  • united states
                  ..........Pins..Q7120....
                  1
                  0.132
                  2
                  0.00
                  3
                  0.01
                  4
                  13.32
                    • 12137
                    • U.S.
                    Measurements seem off did you start on far right leg?? is this your board? see Q7120? it's on the heatsink right by the connector. https://www.shopjimmy.com/sharp-runt...-led-board.htm
                      • 12137
                      • U.S.
                      Test connector PD from mainboard to powerboard on powerboard side with all boards hooked up, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description/name and condition both off and when you hit power on.
                      • hmendez86
                        • Jun 2015
                        • 344
                        • united states
                        I check the Q1720...what i know or think is that 13.32v it should be 12v not 13.32. When i plug the tv led ligth stays lit like tv is on with the main board on the green ligth on main stays lit too...for several secs shutsoff and it start to 3 blinks 1 short
                          13V is the input Voltage feeding that switched 12V LDO regulator, it will not have 12V output until the PNL_PWR control signal (>2VDC) from main board is present to turn on that switched regulator.
                          Right now you need to provide the Voltage readings of the PD connector as suggested, also read the service manual regarding to the error codes.
                          You should also provide good clear pictures of the whole backside of the TV showing all the boards.
                          • hmendez86
                            • Jun 2015
                            • 344
                            • united states
                            I change the power board still doing same thing my only thogth is the main board
                            • hmendez86
                              • Jun 2015
                              • 344
                              • united states
                              • hmendez86
                                • Jun 2015
                                • 344
                                • united states
                                After a while trying to hard reset with buttons it came on the image show small green lines all over......
                                  • 12137
                                  • U.S.
                                  Don't know if it will work but you could try to update the firmware thru usb if fat 32 don't work try fat 16 format.
                                  • hmendez86
                                    • Jun 2015
                                    • 344
                                    • united states
                                    • hmendez86
                                      • Jun 2015
                                      • 344
                                      • united states
                                      Ok ill try to update....but is the lines will disapear if the update is succesfull
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        That image looks like either BGA failure (the solder balls under the processor) or a RAM error.
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • gavenb
                                          Sharp LC-80LE661U 80 inch
                                          by gavenb
                                          Hi folks!
                                          I have a LC-80LE661U that had some interesting issues.
                                          Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                                          I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                                          11-12-2023, 02:05 PM
                                        • SONY_E-WASTER
                                          Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                          by SONY_E-WASTER
                                          Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                          The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                          then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                          does...
                                          12-26-2021, 05:46 PM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
