Sony XBR75X850C
  • bstewara
    • Jun 2019
    • 40
    Sony XBR75X850C
    I am currently trying to repair a Sony Model XBR75X850C.
    The set has the dreaded 6 blinking error lights flashing. The set tries to startup with the screen illuminating but shuts down immediately
    I have replaced the main board but no change.
    So voltages from the G4 board are within range except one anomaly.
    I keep getting a 1.9 voltage reading from pin out location CN 6402 pin 4 BL_ERR. I don’t see where I should be getting any voltage reading from this pin?
    Anyone have any suggestions/recommendations?
    TIA
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Sony XBR75X850C
    The LED flashing 6 times is a back-light error I believe.
    • bstewara
      • Jun 2019
      • 40
      Re: Sony XBR75X850C
      You are correct on the error code.
      I’m just wondering if I don’t have an issue with the ps board as well.
      Thank You
      • diif
        • Feb 2014
        • 6978
        • England
        Re: Sony XBR75X850C
        It's possible, it could also be the LED driver board.
        • bstewara
          • Jun 2019
          • 40
          Re: Sony XBR75X850C
          I found a flow chart and it points to the LD or the G board.
          Thanks again
          • tibimakai
            • Jan 2012
            • 3680
            Re: Sony XBR75X850C
            Anybody knows, what is a 4 blink code could be? It is for a 65X900C
              • 12206
              • U.S.
              Re: Sony XBR75X850C
              one here, also suggests doing a self diagnostic might clear up some issues.
              Four blinks
              - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
              • diif
                • Feb 2014
                • 6978
                • England
                Re: Sony XBR75X850C
                Panel or LD board.
                  • 12206
                  • U.S.
                  Re: Sony XBR75X850C
                  Possibly backlight led failure.
                    Re: Sony XBR75X850C
                    https://www.youtube.com/watch?v=DyRdHSN43Y4
                    Bad LED is more likely. Do you have LED tester?
                    • bstewara
                      • Jun 2019
                      • 40
                      Re: Sony XBR75X850C
                      4 red blinking error maybe LED driver or G board
                      • bstewara
                        • Jun 2019
                        • 40
                        Re: Sony XBR75X850C
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4360
                          • Italy - Milan
                          Re: Sony XBR75X850C
                          Tibimakai why did you entered here with your own different problems? Better to open your own thread..
                          • SLK001
                            • May 2014
                            • 264
                            Re: Sony XBR75X850C
                            The six flash error code is a backlight issue. Most probably, it is a dead LED. I have the 65" version of this TV and all it took was a $0.05 LED to fix. But you really "earn" the fix, because you have to dig all the way to the heart of the set to fix it.
                            • bstewara
                              • Jun 2019
                              • 40
                              Re: Sony XBR75X850C
                              You are exactly right.
                              It's a big job for such a small item to repair
                              • Marty-Club
                                • Aug 2019
                                • 23
                                • United Kingdom
                                Re: Sony XBR75X850C
                                Hi i have the 65 inch version sony bravia with 6 blinking lights , back light error.....
                                can you give me some advice how to remove the pannel......
                                i have done a few Philips 42 inch.......
                                  • 21130
                                  Re: Sony XBR75X850C
                                  Here`s the service manual for the xbr-55x850c, same type of chasis i think. The disassembly instructions start on page 12 .
                                  • SLK001
                                    • May 2014
                                    • 264
                                    Re: Sony XBR75X850C
                                    Do a forum search. This has been discussed in other threads. I started a thread on exactly this issue.
                                    • dkneyle
                                      Sony KDL-46HX850 Can't upgrade/update firmware
                                      by dkneyle
                                      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                      09-25-2024, 10:44 PM
                                      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 05:27 AM
                                      Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                      This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                      09-06-2024, 05:30 AM
                                      Sony VAIO Tap 11 Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                                      This specification for the Sony VAIO Tap 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Tap 11 boardview and Tap 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                      Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                                      This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
