Sony KDL37S5600 power error
  • CasasElectronics
    • Mar 2019
    • 33
    • Spain
    Hi, a friend has brought me the a sony kdl37s5600 motherboard, which has the problem of 5 pulses blinking red led. Thinking that the issue could be the power supply, I've tested the board with my supply, having the same response.
    I've tested all the voltages(supply and dc-dc converters) and all are good at the beginning(because during the red led blinking the voltages disappear).
    In my test conditions i dont have the tcon, so i'm testing the motherboard without it.
    I've thought that the problem will be in my friend's tcon, because if this board has a test voltage which it's measured by the motherboard and it isn't present it will give an error, that is the same error that I've testing the motherboard without tcon.
    I don't have found the schematic to check other poer on voltages, but i think they'll be present.
    Thanks a lot,
    Waiting your responses.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Sony KDL37S5600 power error
    Search for service manual not schematic.
    The LED flashing 5 times is a NVM error.
    • CasasElectronics
      • Mar 2019
      • 33
      • Spain
      I've tried to enter the TT menu, because i've seen in the manual that i can enter the number 41 to restart the NVM, but i can't do that, i've pressed the three keys to enter the mode during 5 seconds and the red key 2 times before pressing 41, without having any response.
      I've tested if the TV responds to the power off pulse of the remote control but it doesn't respond, and I think that the blocking status of it doesn't allow to enter that menu.
      I also cannot see anything on the screen because i don't have the t-con.
      Thanks a lot.
        • 12323
        • U.S.
        Would probably be a lot easier to troubleshoot if you had the whole tv.
        • CasasElectronics
          • Mar 2019
          • 33
          • Spain
          With the whole tv I have the same response, it seems that the operating system is fully locked, and it doesn't respond to the remote signal.
          I have thought two alternatives: or search for the NVM memory and replace it (I don't know where it is located, the component name) or search for a new motherboard.
          What do you think?
          • diif
            • Feb 2014
            • 6978
            • England
            Both the Nand and repair service are available on eBay in your country.
              • 12323
              • U.S.
              Try this test, with tv unplugged from mains, unplug cable from powerboard to mainboard, plug mains back in, what if anything is displayed?
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                The TV does not turn on, the standby indicator is on. All voltages are present.
                Emms is dead. Not readable, not detected.
                Replaced emmc.
                But with another dump there is no launch
                Terminal log
                UART
                AC_ON
                RPMB key is not yet programmed
                HASH1_VERSION=0x00000000 64bit
                E-B
                FDE enabled
                layout pattern onebin by SAR7,0...
                06-01-2025, 02:11 AM
              • PopsCaps
                Sony Bravia KDL-40V2500 that will not power on
                by PopsCaps
                I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                I do not hear any sound and I cannot see any backlight.
                I have tried disconnecting every cable on each board one at a time to see if anything changes.
                The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                03-25-2025, 11:23 AM
                by sam_sam_sam
                03-31-2024, 02:12 PM
