samsung un55f6300af no power
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    Got one of these with no power.Power led flashes repeatedly looks like 2 flashes.Unplugged main board and no lamps even though lamps tested fine as i had panel off and all good with lamp tester.Haven't seen a lot on this model only had one before and lamps were gone on that one.Narrowed down to power supply,as lams don't lighrt with cables off to other board. All caps good 391 v on main cap.Anyone else have this issue?
  • R_J
    • 9627
    Re: samsung un55f6300af no power
    Check CNM803 pins, I suspect you have A5V (standby) but what are the voltages on PS_ON, BL_ON & P_DIM, do these voltages change if the power button is pressed?
    If you disconnect the plug from the main board to the power supply, do you get B5V or B13V, there is a pullup resistor for the PS_ON so the power supply should turn on, but the pullup resistors for BL_ON and P_DIM go to the B5V.
    • sputnikoff
      • Feb 2016
      • 203
      • canada
      The ps on is 3.3 when power led is solid but goes to .25vdc when power led flashing.No effect on any voltages while pressing power button.Only other voltage present 5.3vdc on pin 12.power led cycles solid for short time with 3.3 on ps on then flashes with .025vdc present.
      • R_J
        • 9627
        It does seem like the PS_ON command is coming from the main board, thats good.
        There is a white capacitor (CM811S) near TM801s transformer, if you have a cap checker, check this cap, if not have a close look at it and see if it is bulged,it the sides should be nice and flat.
        I suspect the fault might be with ICM801CS
        Shojimmy has a repair kit that includes this ic
          What is the power supply board P/N? BN44-?????
          • sputnikoff
            • Feb 2016
            • 203
            • canada
            Bn44-00612b
            • R_J
              • 9627
              Have a look at the solder side of the power supply and check the solder connections on TM801CS transformer, they are likely ok but worth checking. the next voltage I would check is the VCC for ICM801CS. Using HOT ground (- of cp807s) check the voltage on JP812 or JP805. I suspect the voltage is there because the pfc circuit is working
                • 12332
                • U.S.
                Wonder if it's a faulty/loose connection in backlight circuit?
                • sputnikoff
                  • Feb 2016
                  • 203
                  • canada
                  Don't think its faulty lamps as i tested with lamp tester each circuit from the cable on back and got very close readings.
                  • R_J
                    • 9627
                    You can disconnect the led lamps completely, that will not cause the missing B13V & B5V
                    and without these voltages nothing else will work.
                    • sputnikoff
                      • Feb 2016
                      • 203
                      • canada
                      RJ hit nail on head with this one it was ICM801CS.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        What did you do to fix the problem? Replace or resoldered loose connection?
                        • sputnikoff
                          • Feb 2016
                          • 203
                          • canada
                          There were no loose connections i could see.I had board under microscope so joints looked good.I replaced that regulator ICM801cs and she powered up perfectly.
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • mrtek
                            Samsung UN43NU6950FXZA No power
                            by mrtek
                            Hi
                            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                            Main fuse = OK
                            Back light LED = OK. Power them with aux power source
                            LED output = OK 156V
                            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                            07-20-2025, 08:06 PM
                          • hill01
                            Samsung UE75MU7009TXZG Endless Power Cycle
                            by hill01
                            Hi everyone and thanks in advance for any help I might get here
                            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                            Since a few days, the TV won't turn...
                            11-17-2021, 02:52 PM
