RCA LED55C55R120Q Main Board Replacement
  • oz_13_ms
    • Jun 2019
    • US
    Hello all,
    I am new to the TV repair scene and am in need of some assistance. I recently purchased a 55120RE01M3393LNA35-C1 Main board for a RCA LED55C55R120Q. In my haste to repair the TV, I forgot to note where the wires connecting to the main board plug into. Is there any photographs or instructions for replacing this board?
  • neilc6
    • Nov 2015
    • 1550
    Re: RCA LED55C55R120Q Main Board Replacement
    You can search your model number in this forum. Found this
    https://www.badcaps.net/forum/showth...=LED55C55R120Q
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • tvguy12012012120
      Picture degrades over ~2–3 minutes (washed out / low contrast) – panel vs T-CON/FRC vs main board diagnosis help
      by tvguy12012012120
      I’m troubleshooting a Westinghouse WD55UW4620 with a strange, very repeatable failure mode and I’m looking for insight on whether this points to the panel itself, T-CON/FRC board, or mainboard.
      Any ideas as to what would cause these symptoms?
      Symptoms:
      • From cold power-on, picture is perfect.
      • After ~2–3 minutes, the image slowly degrades:
        • contrast collapses
        • colors wash out / look incorrect (greens especially bad)
        • image looks “milky” / flat
      • Turning the TV off for a few minutes fully resets it; behavior repeats almost exactly each time.
      • Internal
      01-07-2026, 03:30 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • tuner2000i
      Philips 65PUS8518/12 distorted image after main board replacement
      by tuner2000i
      hello everyone,
      I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
      The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
      07-15-2025, 01:15 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
