Mitsubishi LT-46149 error code 41
  • bartstop
    • Dec 2011
    • 22
    The red power led is glowing solid but tv won't turn on. The service manual says "3.3VS or 5VS STANDBY-SHORT" when I put it in to diagnostics mode.
    Here are the voltage readings:
    Main Board to Power Supply
    DIMMING - 0V
    BACKLIGHT ON OFF - 0V
    INV SHORT - 3V
    INV RELAY - 0V
    PANEL PWR - 0V
    GND - 0V
    PNL 12 SHORT - 0V
    AC OFF - 0V
    MAIN RELAY - 0V
    Power supply to main board
    21 VA - 0V
    21 VA - 0V
    A GND - 0V
    A GND - 0V
    PANEL VCC - 0V
    PANEL VCC - 0V
    GND - 0V
    GND - 0V
    12 VSL - 12V
    12 VSL - 12V
    12 VSL - 12V
    GND - 0V
    GND - 0V
    GND - 0V
    When I first plug it in, I can hear a relay clicking on then back off a second or two later. If I unplug the cable going from the main board to the sound board the relay stays on and "MAIN RELAY" is 3v but the tv still won't turn on. For some reason that sound board is making making the main relay shut off.
    Now here's the weird part. I was checking voltages and all the sudden the backlight turns on. I stand the tv up and I have a blue screen. So, I push the power button and the screen goes black then a Mitsubishi Logo comes on the screen for about 2 seconds. Then the main relay kicks back off. That's happened twice and I can't reproduce it. The second time I wasn't doing anything.
    Does anybody know which pins are supposed to be standby voltage?
    • 12145
    • U.S.
    Re: Mitsubishi LT-46149 error code 41
    Look the powerboard over, on under side, check for cold, bad/cracked solder joints, example: https://www.youtube.com/watch?v=XhlNewlhH3U
    • bartstop
      • Dec 2011
      • 22
      I re-flowed every one that looked even slightly suspicious. Didn't help.
      When I disconnect the sound board from the main board. It gives me code 12 which is "normal off" "no problem detected".
      I ordered a refurb main board. Hope that fixes it.
      • R_J
        • 9535
        Just a note on the 21VA being 0, that is normal as there are no components for that supply ie D9A31, C8a39 etc. are not populated onthe board.
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • JDC
          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
          by JDC
          ONN 100012588
          Issue: No Power, Then Rebooting After Main Board Change
          Short answer: replace main board and power board
          Technical answer: replace main board and Q306 & Q307 on power board.
          Long answer:
          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
