Vizio TVs, defective update? Same symptoms on two different TVs after update
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    So after 2 different Vizio TV's model numbers P502ui-B1E and D55u-D1 got updates there is now a picture latency issue. The sound comes up but the picture takes about a second to show. If I use the channel up button and move up several stations the sound comes up pretty fast but there is a gray screen before the picture comes up. The other problem is when I do a partial channel search the menu flashes on and off several times but the scan continues normally.
    Both TVs worked fine with no issues until the latest update was installed. After though these issues showed up.
    I'm just wondering if anyone else's Vizio TVs are having similar issues after a recent update?
    They call me......."threadkiller"
    Re: Vizio TVs, defective update? Same symptoms on two different TVs after update
    Did you get the update from Vizio?
    • nomoresonys
      • 12331
      • U.S.
      Could be buggy updates, can you roll em back to last firmware?
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        The next morning when I turned it on there was a firmware update notice on screen. Because it updated when the TV was off I presume it came from Vizio.
        Unfortunately not on Vizios, at least that I know of anyhow
          Can you check and see what FW version is on the P502ui-B1E now?
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            Unfortunately no, this is a post-sale TV. The same one I was discussing in another thread. I replaced the main board in it and the problem went away. Apparently the update happened while in the buyer's possession.
            I still have the D55u-D1 (also with a main board replacement before update and onset of symptoms) and I can check the FW version in it.
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              The 55" version: V1.3.34-UHD, FRC version 9.412
              EDIT/ADD: Current firmware version is 1.5.15
                It should be 1.5.16 by now.
                https://www.reddit.com/r/VIZIO_Offic..._version_1516/
                That is 8 months ago, and some people also has problem with new FW as well.
                I would contact as well to see what they have to say about the problem after upgrading the FW.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • jason123
                  Vizio D50-F1 - Can't update Software / Firmware
                  by jason123
                  Wondering if any of you have seen this before. I got this TV with lower half of the screen dim. Fixed the LED backlight issue - smooth
                  I noticed that the System update lists current firmware is V1.0.6 and is able to find on the Vizio server 2.60.23-1... it downloads fully.. but instead of restarting, it just goes back to the previous screen "NO SIGNAL - HDMI1"
                  I got the code and followed the update via flash drive - and it does exactly the same thing. Firmware is copied by the TV 100%, and then nothing - instead of restarting, it just goes back to the previous...
                  08-15-2021, 06:48 AM
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • piernov
                  NVidia bumpgate
                  by piernov
                  Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                  Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                  May complete this post at a later date with more details.
                  Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                  03-27-2021, 10:34 AM
                • TheUser
                  Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                  by TheUser
                  Hello to everyone ,
                  This is my first post here, and i would like to share with you a small story in case you can help me.
                  Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                  All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                  I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                  02-10-2024, 02:07 PM
