lg 43LF5400 - UB
  • nomoresonys
    • 12116
    • U.S.
    #41
    Re: lg 43LF5400 - UB
    "My t-con board F1 is rated at 2 AMPS and 125V is this where I should get 12V?" Yes black probe on chassis ground red probe on each side of fuse, what do you get?? Test is done in this manner not only to verify the fuse but also to insure that there is voltage going to and from it.
    • Rmasters3
      • Mar 2010
      • 126
      #42
      With set "On" I get 13.25 VDC both sides, Thanks
      • Rmasters3
        • Mar 2010
        • 126
        #43
        Replaced main board--works fine now.
        • nomoresonys
          • 12116
          • U.S.
          #44
          Glad to hear it Rmasters3, thanks for the feedback.
          • Pipolups
            Corsair K70 LUX RGB dying LEDs
            by Pipolups
            Hi there !
            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
            10-08-2024, 11:58 AM
          • nathan425
            Samsung UN50EH5300 - No Standby LED, Backlights ON, No Power
            by nathan425
            Hello, I have a Samsung UN50EH5300 in my possession that I'm looking to bring back to life.
            Symptoms:
            • - no power
            • - no standby LED
            What I've done so far:
            - confirmed power supply is OK
            -- CN201 #4 showing 5.3V
            -- BD207 showing 5.3V
            -- removing the cable between the main board and the power board turns on the backlight.
            Pushing the power button on results in no change to any of the pins connecting the two boards.
            - function assembly appears to be NO GOOD
            -- there is no voltage showing on any of...
            11-01-2023, 06:34 PM
          • tvguy12012012120
            by tvguy12012012120
            02-07-2025, 05:13 PM
          • notallbad
            TCL 55RP620K power board issue
            by notallbad
            Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
            0% p_dim at 1.65v and a_dim at 1v
            50% p_dim at 3.3v and a_dim at 1.65v
            100% p_dim at 3.3v and a_dim at 2.88v
            Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
            Leds are 2 rows of 15 6v leds.
            On inspection of the power board found diode MBR3200 shorted so replaced with...
            07-12-2025, 05:45 AM
          • TrisHCl
            LED TV Boot loop - UE40F6500SB
            by TrisHCl
            First post...
            I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
            Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
            I disconnected the main board from the power...
            02-06-2025, 08:42 AM
