Samsung UN55ES7100 Blinking front light and no backlight - clicking
  • jason123
    • Oct 2015
    • 1069
    Unless I'm mistaken, these Samsung TVs typically turn the backlight on when main to PS cable is disconnected.
    This TV does not. Tested the backlight (edge) and they all seem to turn on.
    There doesn't seem to be power to the backlight from the PS. measurement of few mV.
    Main caps only have 162 VDC on them.
    I'm assuming the PFC is not kicking in / working?
    I'd like to fix the board (BN44-00523A), but I haven't had much luck with a schematic.
  • R_J
    • 9559
    Re: Samsung UN55ES7100 Blinking front light and no backlight - clicking
    The backlights don't always come on that way, you may need to force them on, see this fast track guide
    Does your pfc voltage come up when the main to power plug is disconnected?
    • jason123
      • Oct 2015
      • 1069
      Thanks R_J
      The pinouts on this model are a bit different. PWR on / Off has 3.3V on it when disconnected from the main board (assuming high = on)
      I connected it with a jumper to 5 volts, and that didn't make a difference (I could hear the relay on / off)
      I didn't understand that last bit. I had the DMM connected across the large Cap (reading 162 VDC) and unplugged the AC cable, and the voltage started coming down.
      Maybe I didn't understand: "Does your pfc voltage come up when the main to power plug is disconnected?"
      • R_J
        • 9559
        when the power supply is in standby mode, the voltage across the main cap (120vac input) will be around 160vdc, when the power supply is turned ON, the pfc circuit starts and boosts that voltage to around 380vdc
        The pfc should come up with the main to power plug disconnected, the other voltages should also come up
        Usually the PS_ON pin is connected to the standby voltage with a resistor and main board holds this pin low, so when the cableis removed the pullup resistor takes the PS_ON to the standby voltage, so maybe check the transistor that is connected to the ps_on pin to see if it is ok and not keeping the power supply from turning on.
        • jason123
          • Oct 2015
          • 1069
          The PS_ON on the power supply, whether pulled up to 3.3, 5.1V or gnd, doesn't turn on the Backlight, and the voltage across the big caps is not changing from 162-161 V DC.
          This suggests the problem is within the PS board, correct in my assumption?
          • R_J
            • 9559
            The PS_ON pin should turn on the power supply main supply and pfc only, and give you B5 and B13 volts, not the backlight, that can use a different pin/s
            Have you checked the fuses FP802s & FP803s?
            I see shopjimmy lists a repair kit for this board, maybe check the parts shown in there kit
              • 12206
              • U.S.
              So what pins did you jumper #3 and #17? on some you need to use the bu 5 v pin.
              • jason123
                • Oct 2015
                • 1069
                referring to the photo here (PS labels), with the connector unplugged from main
                Pin 20 is 3.3 V
                Pin 18 5.14 V
                No other voltages are present.
                I jumpered 20 to 18 = No state change (no clicking)
                connected 12 to 18 and to 20 = No change
                Connected 3 to 18 = no change
                In all the combinations above, B5V, or B13V never came on.
                • R_J
                  • 9559
                  I would'nt worry about the backlight circuit, you first need to get the B5v and B13v working.
                  Did you check what I asked before?
                  You say pin 20 is 3.3v, that is with the plug disconnected from the main, Pin 20 should have a pullup resistor connected to A5v. It then connects to another resistor to the base/gate of a transistor. That transistor may be bad and if it is the power supply will never turn on.
                  Locate QQ852 and check the resistance between the gate (marked in red) and ground, next to it is QQ856, it might be shorted also.
                  • jason123
                    • Oct 2015
                    • 1069
                    Resistance between base & gnd is 67.6k (keeps going up slowly) high impedance on the other transistor as well. No sign of shorting
                    • R_J
                      • 9559
                      I guess RS852 must be a high value (100k) so it drops the A5V down to 3.3V at that PS_ON pin. similar to this circuit
                      Does the relay still click off and on with the main disconnected?
                      • jason123
                        • Oct 2015
                        • 1069
                        Yes, the Relay clicks when I short the PS_ON to GND
                        • R_J
                          • 9559
                          Shorting the PS_ON to ground would be turning the power supply OFF and placing it in standby. When PS_ON is high does the relay only click once or keep clicking?
                          At this point I will assume the two fuses are ok.
                          • jason123
                            • Oct 2015
                            • 1069
                            It only clicks once. When I connect the main board, and turn the TV on, in addition to the blinking, it seems that it would start to tun on, then off.. so on.
                            Yes, all 3 fuses on the board are OK. I checked the larger FETs and Diodes, and I don't see anything out of the ordinary (shorts)
                            • R_J
                              • 9559
                              Now you need to find out why the B5V and B13V are not turning on. The ic that drives that circuit is under the small heatsink near CP811 cap.
                              Check if RM807 is ok and not open
                              On the hot side QS801 I believe is the VCC switch that supplies VCC to ICM801, using hot ground , check the voltage on PC8025 (opto) collector and emitter
                              The ICM801 might be a FSFR1700 or similar ic, it requires VCC on pin7 (~12volts) which is usually supplied by transistor QS801 and then switched by a transistor likely QM852
                              • jason123
                                • Oct 2015
                                • 1069
                                RM807 reads about 0.5 ohm. Opto PC802S reads 12.9v and 13 v on the hot side pins. The other transistors seem to not be shorted. Any measurements on those is needed?
                                • R_J
                                  • 9559
                                  Does icm801 have vcc on pin 7, You can check for it on JP804 or JP903 That VCC voltage is also needed to turn on the pfc section icp801s
                                  The opto has 13 volts on e & c which indicates it is turned on, so ps_on must be working.
                                  • jason123
                                    • Oct 2015
                                    • 1069
                                    JP804 has 10.7V referenced to hot gnd
                                    • R_J
                                      • 9559
                                      Usually once the pfc ic (icp801s) gets its VCC it should turn on and you would get the boosted voltage on the main cap
                                      Whats the number on icp801s?
                                      • jason123
                                        • Oct 2015
                                        • 1069
                                        Spc7011f
                                        • learnmore
                                          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                          by learnmore
                                          Hello Community!
                                          CASE DETAILS
                                          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                          Tried inserting firmware on USB and left it in for a few hours, but no change
                                          03-03-2024, 09:49 AM
                                        • matty24
                                          Samsung UE50MU6172 - red light blinking
                                          by matty24
                                          Hello. I have problem with Samsung UE50MU6172.
                                          TV won't turn on, red standby light is blinking.
                                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                                          Main board BN41-02568B (BN94-12530E)
                                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                          03-02-2025, 08:57 AM
                                        • Fergal22
                                          Samsung UE40F5300AK blinking red light
                                          by Fergal22
                                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                          Any help would be appreciated...
                                          02-02-2023, 09:19 AM
                                        • Davi.p
                                          Samsung UE49MU6120 no boot, no spy led, blinking backlight...
                                          by Davi.p
                                          Hi folks, the set is from my brother house, unfortunately i'm repairing 1 tv, 1 pc, 1 tablet, 1 Stereo receiver at the same time, all house's bench/table busy, i eat like an horse, and i'd like to know sure experience from other techs about this, i don't like to transport it to my house and it ends it is bad backlight waiting months for parts and so on..
                                          The blinking is only on the left side, no answers from remote, right after plugging in, back story of tv it had some slight B.L. problem, some shadowing in the bottom of image, maybe burnt sheets.. i really hope it's the same old spi flash...
                                          08-27-2024, 08:07 AM
                                          09-07-2024, 05:50 AM
