Sharp Aquous 60" LCD tv TCON or LCD issue?
  • gogoo
    • Nov 2017
    • 8
    Hi guys
    I just got this 60" SHARP Aquos TV for free but it has a problem.
    1/4 of the LCD panel shows weird colours and artifacts. as seen on the attached picture.
    I tried swapping the sides of the tcon board but the problem follows so I'm not sure what the issue is bad ribbon cable bad bonding cables to the LCD panel or ????
    Please help.
  • gogoo
    • Nov 2017
    • 8
    Re: Sharp Aquous 60" LCD tv TCON or LCD issue?
    The question is is it repairable or should I just part it out?
    • jjanssen7
      • Nov 2012
      • 252
      What is the model number?
      • rccrasher65
        • Mar 2014
        • 625
        no panel
        • budwich
          • Jul 2015
          • 3097
          Hi guys
          I just got this 60" SHARP Aquos TV for free but it has a problem......
          Please help.
          what does this mean... how or what did you swap? Your well described action will likely indicate what the problem is so be very good in your description.
          • gogoo
            • Nov 2017
            • 8
            The Model Number is LC60LE660U 60" Smart TV
            • gogoo
              • Nov 2017
              • 8
              I don't have any spare boards for this unit so to check to see if it's a TCON issue I swapped the ribbon cables going to the Panel from the left side to the right side and the problem was still on the left side so it looks like the TCON board is fine. I think I might be out of luck.
              • budwich
                • Jul 2015
                • 3097
                but your initial statement indicates that when you swapped, the problem follows??????
                anyway, with the clarification, it does not look good as "vertical distortions" are usually a sign of a panel issue especially if it is a smaller section of the panel / side.
                You try inspecting the tabs along the bottom on the troubled side to see if perhaps there is an obvious issue with a connection... maybe someone did some "window washing".
                  • 12220
                  • U.S.
                    • 12220
                    • U.S.
                    Here's a problem I've seen a few times, fixed mine the same way but I just shimmed the ones with poor contact:https://www.youtube.com/watch?v=vCExlSnG4yY
                    • gogoo
                      • Nov 2017
                      • 8
                      Thanks I will give it a try
                        • 12220
                        • U.S.
                        Be very careful handling the panel theyre VERY flimsy and easy to break, even the pros break m, be careful not to over tighten any screws that might be in the frame, on reassembly.
                        • gogoo
                          • Nov 2017
                          • 8
                          Well I found the problem. the panel is garbage but the rest of the boards are fine.
                          one of the the ribbon cables bonded to the lcd panel had the surface mounted long thin IC cracked in half.
                          • jjanssen7
                            • Nov 2012
                            • 252
                            LED sidelighting might be worth money... PM me if you are interested in parting out?
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              The Sharp LCxxLExxxxs are known for failed panel drivers.
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              Arc A770 16 GB
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
                              • x_orange90_x
                                TCL 50S535 bad tcon or panel issue?
                                by x_orange90_x
                                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                03-29-2025, 11:02 PM
                              • thelankanguy
                                Sony KD-55X9000F TCON Issue
                                by thelankanguy
                                The TV shows a black screen with no image.
                                TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                Later both ribbons were disconnected and TCON voltages were tested.
                                12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                There is also a short to ground in this circled inductor.
                                Is this a TCON issue or something else ?...
                                12-13-2024, 12:27 AM
                              • cagri
                                BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
                                by cagri
                                I have an Arcelik TV with BOE HV650QUB-F70 TCON board, but I think there's an issue with/around PMIC.
                                PMIC: iML8940
                                There is backlight and sound, but no picture. I watched a YouTube video and turned it off, half an hour later it was dead.
                                Input 12v, fuse ok
                                DVDD1V2 = 1.2v
                                DVDD1V8 = 1.8v
                                DVDD3V3 = 3.3v
                                VGL = -7v
                                **VGH = -0.3v
                                **VCOM0, AVDD, HAVDD = 0v
                                SWBK1 = 3.3v
                                SW1 = 12v
                                VGH to GND resistance is 500kohm as expected
                                Readings are same after I disconnected the two cables from TCON to panel...
                                07-27-2023, 09:48 PM
                              • claytongarcia
                                Issue with Sharp LC-42SB45U
                                by claytongarcia
                                I recently got a model Sharp TV, and I've noticed that the green power LED is flashing without any specific pattern. Additionally, there appears to be no voltage coming from the power board. I haven't observed any leaking or bulging capacitors, although the top of the larger capacitor doesn't seem to be perfectly flush with the jacket—if that makes sense.
                                Has anyone dealt with this issue before?​
                                03-10-2025, 07:27 PM
                              • advant
                                by advant
                                02-03-2020, 12:25 AM
