Vizio M43-C1 No Backlights
  • alfatv
    • Sep 2020
    • 353
    Re: Vizio M43-C1 No Backlights
    Originally posted by jjanssen7
    The M43-C1 is a great candidate for a panel swap. The LCD panel fits into several Sharp and Insignia 43" models manufactured in the similar time period. So just buy one of those "cracked screens" and swap the panel and tcon over. No mods needed.
    Just a thought....
    What are those models please
    • edhuk
      • Feb 2021
      • 5
      Great suggestion!
      The $20 power supply board arrived today and, as predicted, didn't fix the problem. Exact same symptoms Fading power light then 15 flashes just like the existing board that tested with good voltages.
      So, I'll keep looking for a main board and may try a reflow using my heat gun. Not sure if I'll try oven baking as I see it melts the plastic parts on the main board as per a YouTube video.
      Cheers!
      • edhuk
        • Feb 2021
        • 5
        Just a thought....
        Great suggestion!
        Cheers!
        • howardc64
          • Jun 2017
          • 636
          Heat (reflow) main board in toaster oven @ 375F for 8min (board surface temp will read ~400F using laser temp gun). Make aluminum foil ball for feet to keep board/components off of metal tray. Its the best DIY solution without BGA reflow tools.
          Better if can remove heat sink before reflow but most of these main board's heat sink is soldered on and very difficult to remove.
          Fixed 2 of these Vizio boards and a Nintendo switch main board with this method and been running for a few months now
          • jjanssen7
            • Nov 2012
            • 252
            Rather than messing with reflows that in my experience only last a couple of months (at best) and therefore cannot be resold, I take the panel out of M43-C1 and put them in a new but cracked screen unit. Substitutes are:
            Toshiba 43L621U
            Toshiba 43LF621U
            Insignia NS43DR710 (Warning, this model has bad LED lifetime too)
            Sharp 43LB591 or the next year's model too (43L711?)
            In all these cases, the screen and tconn together are swapped. No modifications required beyond that.
            • edhuk
              • Feb 2021
              • 5
              Thanks for your quick reply!
              I was considering the reflow route but many posters here say it won't last long even if the reflow works.
              In looking at the heat sink it appears to be soldered to the underside of the board at 5 points. If I remove the 5 blobs of solder the heat sink should come off, right. I could then use the heat gun route to reflow the two main chips.
              • diif
                • Feb 2014
                • 6978
                • England
                #87
                Without intentionally being rude, don't be discouraged by amateurs that aren't doing it right.
                Lead free solder melts at around 217°C or 422°F.
                A decent reflow will last years, I know as I've done plenty.
                • R_J
                  • Jun 2012
                  • 9588
                  If something is not working and trying a repair MIGHT make it work, it is worth a try. Have a closer look as I believe there are 6 solder connections for the heatsink. It might also be the U202 eeprom ic. shopjimmy has them available $15.00 If you go this route there are 2 different ones depending on the board numbers.
                  • Diah
                    • Feb 2013
                    • 6435
                    common.. only BGA reball will last years... others are could be days or more.. the problem its the soldering pasta when they apply it to the boards at first time before installing parts on it and then boards go to oven. in this manufacturing procedure allot in china they didn't used camera robot after the stencil pasta step to exam the pasta placing amount, even whom used this camera step where it should adjust to not less 95%. some reduce this tolerance even to 60% if they have busy orders. so any boards manufactured under this wrongdoing will face BGA issue. so what the decent reflow can do when the paste are so little. !!
                    • alfatv
                      • Sep 2020
                      • 353
                      Have you done it for this particular M43-C1?
                      The problem is with 2 chips running very hot which leads to new failures.
                      I am thinking of attaching 2 heatsinks with fans like this in place of original heatsink
                      https://www.aliexpress.com/item/4001080930094.html
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        #91
                        I've not seen a Vizio over here but I've reflowed and quite a few TV mainboards and have yet to have one back.
                        It's about 5 years old ? there's no reason a well done reflow shouldn't last as long. You can add a fan and heatsink although, it will still get hot and it will still expand and contact when going from off to on and vice versa. How hot do they get ?
                        The biggest cause of failures of home reflows is they weren't done hot enough from the temperatures I keep seeing them done at.
                        I'm ignoring those that kill them with a heat gun.
                        • alfatv
                          • Sep 2020
                          • 353
                          I measured 65 degC on top of heatsink with back cover removed.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #93
                            You highlighted the most important bit. Decent reflow board preheated, accurate temperature profile and flux, why shouldn't it last as long again ?
                            Yes, replacing the balls with lead provides a much longer life, but on some things it's not worth it. Maybe they are junked but I don't hear anything back.
                            • DXseekerMO
                              • Feb 2018
                              • 1119
                              • US
                              #94
                              I find on Vizios when there is 15-19V on the 12V line and there is no 12V at the timing control board "VIN" test point that the Main Board is the culprit. This includes the Viz M50-C1.....and SO MANY MORE!
                              If your M50-C1 Viz has multi-colored pixels at either lower corner of the screen when turned on the screen is probably shorted. Try detaching one FFC from the T-CON at a time and see if the screen is white on one side and the picture comes back upon the other. Whichever FFC is detached when half the picture returns is the shorted side. I now use an M50-C1 with a shorted screen and 1 FFC taped over 6 traces as a tester TV.
                              Once you find which side is shorted cover at least 6 traces on the outboard side of the FFC with scotch tape, re-insert the FFC in to the T-CON and see if you have a full picture. If not, cover one more trace at a time until the picture returns.
                              M50-C1's that appear to turn themselves on over and over with no picture or multiple flashes of the status light probably need a Main Board.
                              M50-C1's need Power Supplies a lot less than what you think!
                              Unless the T-CON fuse is blown the T-CON is most likely good on your M50-C1
                              The NUMBER ONE FAILURE on the M50-C1 is the Main Board.
                              They call me......."threadkiller"
                              • nomoresonys
                                • 12272
                                • U.S.
                                #95
                                Very good info DXseekerMO, thanks.
                                • johnboiles
                                  • Dec 2020
                                  • 10
                                  My simple heatsink-on toaster reflow from mid December is still working fine! I'm truly surprised! If you don't have the skill or tools to get the soldered-on heat sink off, just try a toaster reflow with it on first!
                                  • howardc64
                                    • Jun 2017
                                    • 636
                                    Proper reflow with good BGA reflow station is certainly the best solution but inaccessible to most people budgeting < $100 for fix (new disposable 50" UHD TV @ $200)
                                    Cheap toaster oven reflow temp is imprecise with temp setting not matching temp @ BGA. Thats why I proposed 375F-400F (below lead-free melting temp). Temp around BGA could be slightly higher (my IR temp gun (what I had, obviously not good as thermal couple) shows 400F+ @BGA with 375F setting on my cheap toaster oven)
                                    Removing soldered on heat sink is difficult with sink drawing away heat from the soldering iron. I used 2 irons (1 is $200 Hakko desoldering gun with a pulsed pneumatic suction tip), 2 people and gradually worked free all the solder points. Used limited amount of leaded solder to install in case need to remove again.
                                    Tried fan cooling. Small fan hidden inside TV don't have enough airflow to achieve any temp reduction. Probably need to cut back of panel (or leave the back off all together), use big fan (more flow with lower noise) to make any temperature difference. Fan won't rescue a board that needs reflow so still need to reflow.
                                    In my experience, toaster oven reflow lasting much longer than heat gun reflow so far. Primarily because I didn't dare to apply heat gun too much (with heatsink off) as it can easily damage the BGA+board. Toaster oven offers better temp "control" even if horrible by good BGA reflow station standards.
                                    Anyway, just offering cheap none repair shop TV owner solution My heat sink off toaster oven reflow devices (2 TVs, 1 Nintendo Switch) are all still working as well. TVs seen about ~100 hours use since reflow so not heavily used.
                                    • Dananar
                                      • Apr 2021
                                      Wondering if changing main board from a M43-C1 lttwspar serial with the one for lttwsear will work...
                                      • Dananar
                                        • Apr 2021
                                        See post #5 on this page from jjanssen7.
                                        If the panel + T-con board swap works...I believe swaping the PS + MB + T-con from another M43-C1 with a different serial starting characters should work ?. Ex. From a Lttwseac to lttwspar....
                                        • dsant90
                                          • Jul 2020
                                          I had the same problem as Neilc6 with my M43-c1. I removed the Mainboard and its heatsink, covered the components around the cpu to shield them from the heat. Pointed the heater at the cpu while monitoring its temperature with a laser thermometer pointed at it. Once its temp reached 121 degrees C, I began timing it with a stop watch and kept the temp between 121 and 130 for 5 minutes. Then repeated the procedure with the second CPU. Then let it cool to room temp and put everything back together. Tv is fixed! I don't know how long it will last, but I did the same with a Vizio D55u-D1 and that is still working after two months. I am not a technician or tv repair expert and I know nothing about the internal architecture of a CPU, but I learn about this from a Youtube video posted by Louis Rossmann who is a laptop repairman. Using this method you don't expose any of the other components to intensive heat.
                                          • bpcannan
                                            VIZIO M557-G0: Backlights or ???
                                            by bpcannan
                                            'Morning,
                                            I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                            Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                            I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                            I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                            10-29-2023, 06:36 AM
                                          • csmith
                                            Vizio-D50u-D1 Pulsating Backlights
                                            by csmith
                                            This Vizio came in the shop with no backlights. Replaced all the strips with replacement from Shop Jimmy. Set now has backlights but lights pulsate on left side. Half the screen brightens up then goes to normal then repeats.
                                            Am I looking at a defective strip? Thanks in advance.
                                            11-07-2024, 02:56 PM
                                          • x_orange90_x
                                            Replacing backlights in Vizio V755-J04
                                            by x_orange90_x
                                            I've had this monster for several months as I've hesitated to order backlights for it. Finally did order them and they are due to arrive tomorrow. Besides having ample space to work, are there any recommendations for working on such a massive screen? Should I remove the panel by myself or would 2 people be a better choice? I bought the double-cup suction cups from Harbor Freight and have been using them for the last few repairs on smaller screens. They are far superior to the single cup orange ones I used previously that would often let go without warning 😱.
                                            I have not replaced...
                                            12-03-2024, 07:03 AM
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
