Panny TH-42PA20 Service Menu?
  • Inssomniak
    • Apr 2019
    • 16
    Picked up this oldie PDP and want to know how many hours on it, but all instructions for a service menu dont work. Anyone have any ideas?
    Thanks!
    LCD LED TV Service Menu Codes
    TCL LED TV Service Menu Code
    LG LED TV Service Menu Code
    10-31-2024, 03:58 AM
  • Robby-Gr
    TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
    by Robby-Gr
    I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
    However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
    The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
    Additional issues:...
    09-27-2025, 12:02 AM
  • tusiime
    How to access Vizio m652i-b2 service menu
    by tusiime
    The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
    So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
    Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
    09-15-2023, 09:57 AM
  • intercepter
    JVC LT-32CA120 service menu
    by intercepter
    I have JVC LT-32CA120
    Board:Vestel 17MB171
    I need rotate screen.It is possible in service menu and how to enter service menu?
    Thanks.
    12-10-2024, 10:29 AM
  • alltvrepairs
    Jvc Lt-65VU3000 reduce backlight from service menu
    by alltvrepairs
    I have just replaced led set of this vestel tv due to age.
    I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
    Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
    Thanks again....
    09-20-2025, 05:03 AM
