Please help.. Need it..
need philips 32pfl3409S/98 spi flash firmware file
by ahmedtouHi everyone,
help me please
I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
I will share all the details with you, including the disc information.
Code:HL-DT-ST BD-RE GGW-H20N XA02 (ATA) Current Profile: BD-R Disc Information: Status: Empty State of Last Session: Empty Erasable: No Free Sectors: 12,219,392 Free Space: 25,025,314,816 bytes Free Time: 2715:27:17 (MM:SS:FF) Next
by zoltorGood afternoon. The Canon G3430 is lit by lightning after the firmware, it does not respond to the buttons. I did not flash it, they brought it with traces of soldering, and all three chips. SPI - IC401 25Q128, IC402 25Q32, IC403 M24128. The SPI flash drives may have been confused in places. The QM8-0985 formatter. I've tried all the firmware available on the Internet, and the result is the same. I ask you to send dumps of chips, if someone has the same revision of the board, also tell me if the location of the SPI flash corresponds to the position numbers. Thank you very much in advance.09-17-2025, 12:40 AM
by GeckoGreenHi,
I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
Will you please help me get the [2D63]LOGIC.bin file for my TV?05-17-2025, 02:47 PM -
by sikocanI believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
SN: PF3G1REP
MODEL: 20KW-00J1AU
PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
Channel: BIOS Requests ONLY!
by macabookHello everyone,
07-24-2025, 02:17 PM - Loading...
