Vizio M3d550kde Black and White screen menu has color
    • 12178
    • U.S.
    Re: Vizio M3d550kde Black and White screen menu has color
    Can't say for positive but a new mainboard should do the trick.
    • Mr.Nientiendo
      • Jun 2019
      • 32
      Theres no lock out procedure checking like to see it has to be the same model as the old board in tv to be compatible I hear rumor ifts not just gets stuck on the logo screen as it turns on
        • 12178
        • U.S.
        You want to match up the numbers of the white sticker on the mainboard, the one starting with TXCC.
        • Mr.Nientiendo
          • Jun 2019
          • 32
          Hello and thank u guys for replying I have decided to find the board on eBay now I match the tx number thts on board cost me $100 now I'm stuck with board cause the guy said this not the one for my tv y is tht I'm confused does it have to do with firmware perhaps this boards are hard to find by the way ok so this is picture of my board of tv and the one I bought the one with blue line on top is the board from ebay
            • 12178
            • U.S.
            Who said it wasn't a match? Those 2 boards sure look like a match, just like this one: https://www.shopjimmy.com/vizio-cbpf...-m3d550kde.htm
              • 12178
              • U.S.
              #26
              What's your panel sticker number?
              • Mr.Nientiendo
                • Jun 2019
                • 32
                Hi friends thnks for replying is this the sticker you're talking about ? 🤔 And the guy who sold me the board says tht they don't have the board I'm looking for my T.V
                  The model number of the LCD panel is on the sticker on the back of the LCD panel.
                  • Mr.Nientiendo
                    • Jun 2019
                    • 32
                    Hi yes it's the sticker ure talking about correct or can send me a example of it and we're to find? Or is it like literally were I have to open tv and look of the back lcd panel while the tv is opend up if so dam let me open it up and resend it ��
                      • 12178
                      • U.S.
                      #30
                      NO, you need to take the back cover OFF, then look on the metal chassis, it will be on a sticker sticking to the chassis, sometimes it will be under some type of shield that may also need removed but not usually.
                      • Mr.Nientiendo
                        • Jun 2019
                        • 32
                        Ohh ok I got it they well there sending board will replace keep u guys updated if don't work in sure I can return with eBay policy from wht i was told do u guys know of any good lead free solder not to expensive on eBay or so on
                          • 12178
                          • U.S.
                          #32
                          Actually the seller isn't responsible if you order the wrong board, they're only to blame if you get a faulty board, it's up to you to match the boards or ask seller if knowledgeable, if it's a match. I had that problem once, sold a board to a "tv shop" they bought the board, board didn't work for them, they said it was broken, they want a refund, I asked what their panel number was, wasn't even close. Mistakes are made, I refunded minus shipping, wasn't about to pay shipping for their mistake, now I ask the necessary info. of any buyer, no matter if they call themselves a "tv shop" or not, to try and minimize these mistakes. Sell very seldom tho, not much left after ebay and others get 13% off the top, not to mention shipping, It wasn't my fault or ebays or the shipper, it was a stupid mistake by someone who didn't do their homework.
                          • Mr.Nientiendo
                            • Jun 2019
                            • 32
                            Hi asked the seller he says to his knowledge it is the same board how ever I'll try to install see if works if not I'm fckd 🙄 any way wht numbers on the back of panel needs to match with my board to take look 🤔
                              • 12178
                              • U.S.
                              #34
                              Top row 4th one from the left: "PANEL MODEL NUMBER" https://www.google.com/search?client...uact=5#imgrc=_
                              • Mr.Nientiendo
                                • Jun 2019
                                • 32
                                Ok Thank you for replying I'll just wait for board to get here and update process of tv now 🙄
                                • Mr.Nientiendo
                                  • Jun 2019
                                  • 32
                                  Ok guys updated received new used board replaced put back together fired up and results I just wanted to thank u from bottom my heart guys for ur assistance and help and replying 🙏 thnk u
                                    • 12178
                                    • U.S.
                                    #37
                                    Glad to hear it, thanks for followup report.
                                    • Mr.Nientiendo
                                      • Jun 2019
                                      • 32
                                      Sry to bother guys question the smallest lil clip on right side wht is for? Or wht does it do cause on my new board it's missing how ever the pings lil metal contacts pins are there and I manage to connected to the pins do i require this clip to be on my board as well or?
                                        • 12178
                                        • U.S.
                                        #39
                                        Not sure what "clip" you mean, try it without hooking it up, if there's no problems you might not need it.
                                        • Mr.Nientiendo
                                          • Jun 2019
                                          • 32
                                          This one were it's circled sry I Ben having problems uploading pics and videos any way my main question wht is this plug for? And and is it required it has tht clip cause my new board is missing it but I managed to connect the connection to the little metal prongs were it's suppostly connects
                                            LCD LED TV Service Menu Codes
                                            ALL LCD LED TV SERVICE MENU CODES
                                            Service Menu Code with Board Name
                                            China Universal Board / Jumper Board Service Menu Code
                                            Changhong Ruba Service Menu Code
                                            Ecostar LED TV Service Menu Code
                                            Orient LED TV Service Menu Code
                                            Haier LED TV Service Menu Code
                                            TCL LED TV Service Menu Code
                                            Samsung LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            Videocon LED TV Service Menu Code
                                            Supra LED TV Service Menu Code
                                            Toshiba LED TV Service Menu Code
                                            Symphony LED TV Service Menu Code
                                            Veste/ LED TV Service Menu Code...
                                            10-31-2024, 03:58 AM
                                          • tusiime
                                            How to access Vizio m652i-b2 service menu
                                            by tusiime
                                            The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
                                            So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
                                            Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
                                            09-15-2023, 09:57 AM
                                          • brad2157
                                            Vizio E70-E3 Two white vertical lines
                                            by brad2157
                                            I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                                            Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                                            Replacement main board - Boots up fine, but starting...
                                            12-13-2021, 05:11 PM
                                            MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                                            This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 07:46 AM
                                            MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                                            This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            09-06-2024, 07:29 AM
