Sony Bravia KDL 46EX520 Faulty T-con board or LCD panel -- Horizontal lines
  • Kieran87
    • May 2019
    • 3
    Yesterday, horizontal lines appeared on my television and I am unsure whether the problem lies with the T-con board or LCD panel.
    I have removed the back housing and visually there are no obvious electronic issues. I then removed one of the ribbon cables from the T-con board, which resulted in blacking out half of the screen and the other half appeared normal (ie problem resolved - no distortion). I replaced the ribbon and then removed the second ribbon and there were horizontal lines across the entire screen.
    I have attached several photos.
    Any advice or other checks would be appreciated.
    Thanks in advance.
  • budwich
    • Jul 2015
    • 3097
    Re: Sony Bravia KDL 46EX520 Faulty T-con board or LCD panel -- Horizontal lines
    the last two picture show vertical lines... those are usually not good as there is likely a problem with the panel near that area. You can check the tabs in and near the area. Is the panel on this set connected to a small edge board at the bottom or top? You might get lucky by carefully checking the edge board for a component failure (resistor or capacity). The corner area also drives the side of the panel which is the reason that you see the lines in the second picture.
      • 12196
      • U.S.
      If no luck finding/fixing fault, the "cutoff tape" method might get you a good image.
      • Kieran87
        • May 2019
        • 3
        Thanks for your responses.
        The edge board is on the bottom and seems quite hard to get to. I will check the panel tabs tonight.
        If it sounds like it might be a panel problem it looks like i will be needing a new TV.
        I dont know what the "cutoff" tape method is.
        Thanks again.
          • 12196
          • U.S.
          Not much to it, may have to play with the width of the tape to get it right, might work might not: https://www.youtube.com/watch?v=j7vl7-vZEL8
          • ggil44
            Sony XBR-65X750D Horizontal lines bottom of screen
            by ggil44
            Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
            05-30-2023, 07:51 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • Raulnn
            Sony KDL-50W685A horizontal black lines Pattern
            by Raulnn
            good morning! I have a problem with this Sony. The image has a pattern of black horizontal lines, I attach a photo of the lines. The power supply is external and emits a sound. I don't think it's because of that. Let's see if someone can help me.
            12-10-2023, 06:50 AM
          • dvu0627
            Sony XBR65X900H TV with Horizontal Lines right half of screen
            by dvu0627
            I have a Sony Smart TV XBR65X900H that started to have horizontal lines on the right side of the screen (see attached picture). When I played video on Youtube green horizontal line at regular intervals(1/4") across the screen.
            I replaced the T-Con board but the lines are still there.
            I believe this issue is from the Main Board. Before I replace the Main board, I wanted to seek advise if this is the problem from the Main board or something else?
            Thank you for the help....
            02-05-2023, 03:39 PM
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
