LG 60PV400-UB plasma TV with sound but no picture FIXED
  • Yanleb
    • May 2017
    • 102
    Hi all, I just want to share the fix on a LG 60PV400-UB plasma TV. It has sound, but no picture.
    The power supply was ok, supplying VS and VA to the Y sustain board.
    The Y sustain board (EBR73561201 or EAX64232001) had no VSB and VY voltage. Still no VSB and VY after disconnecting the Y buffer boards. The only problem I found was an open fuse at position FS104 (2A 125V).
    Before reconnecting the Y buffer boards, I checked them for shorted buffer chip. And as expected, I found one at position IC251 on the lower Y buffer board (EBR73561001 or EAX64231901). Chip model is R2A2O296FT. What's funny is that the original chip was made in Malaysia while the only replacement chips I can find are made in Japan. The ones made in Japan are said to be original and those made in Malaysia are said to be fake. What? LG is using fake chips in their TV sets? I don't understand.
    Another problem was found on the Z sustain board (EBR73561701 or EAX64232101). It had no VZB voltage (Z bias). I found a ceramic capacitor partially shorted at position C210. It was dark brown due to overheating. It is connected to IC216. To find its value, I looked at C282 which is connected to IC215 in a similar way. Value of C282 measured 4.7uF. So I replaced C210 with a 4.7uF ceramic capacitor salvaged from another board. VZB is back.
    This TV has been beaten up. On the main board (EBT61405091) the connectors for HDMI3 at position JK503 and the optical out at position JK604 were both ripped off from the board. I'll let them as is, since I don't need them and finding replacement parts is almost impossible.
    Thanks to LG for providing the details to do the alignment for their plasma TV sets. I've adjusted the VS, VA, VSB, VY, VZB, Set-DN and Set-UP voltages for a perfect picture.
    The fixes described in this post will also apply to the following TV models from LG :
    60PV250-UB
    60PV400-UB
    60PV490-UC
    60PV450C-UA
    60PV450-UA
    60PZ550-UA
    60PZ750-UG
    60PZ850-UA
    60PZ950-UA
    And this one from Zenith :
    Z60PV220-UA
    I hope it can be helpful to someone. If that's the case please reply to this post. Thanks for reading.
  • Unspun01
    • Jun 2011
    • 349
    Re: LG 60PV400-UB plasma TV with sound but no picture FIXED
    Thanks for posting. I'm sure someone with this TV model will find this valuable
    • Bubbsy 2002
      • Nov 2010
      • 56
      60PV250-UB
      60PV400-UB
      60PV490-UC
      60PV450C-UA
      60PV450-UA
      60PZ550-UA
      60PZ750-UG
      60PZ850-UA
      60PZ950-UA
      Z60PV220-UA
      Hi, I have the same TV, initially I soldered the coils on both y and s board, that are known to have cold cracked joints ( picture was weird, fixed after resoldering). 5 months later I started to see some anomalies on the screen and screen would shut off, then one night I felt the heat coming from YSUS, heard some noise buzzing sound then black screen. Power works etc.
      I found large main fuse blown on YSUS board, but others are ok, any help would be appreciated.
      I am thinking some FETS are blown.
      Thanks,
      • ghostridertech1968
        • Sep 2021
        • 6
        I was wondering if someone could tell where I could get a diode that's on the YSUS board on the back side. Its D428 and the markings on it are as follows 88 ad below that is 15.
        • KYBOSH
          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
          by KYBOSH
          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
          No picture but you hear the TV static (white noise) playing loud and clear.
          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
          But it seems they didn't get too far and just left it.
          When I first took a look I was amazed at how pristine the inside looked.
          Its as if the TV had been in a time capsule.
          Caps looked like they were just pulled off the self.
          Copper coils had no sign of corrosion on...
          02-01-2023, 11:10 PM
        • KYBOSH
          Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
          by KYBOSH
          Saved this beast from the landfill this weekend.
          Manfactured July 2013 in Mexico.
          I love working on plasma TVs.
          Its been a while but I was lucky enough to find 2 this week.
          The TV powers on and stays on but no picture. Havent checked for sound yet.
          No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
          Will start troubleshooting tonight.
          10-17-2024, 01:17 PM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
