Re: VIZIO M552i-B2
VIZIO M552i-B2
Re: VIZIO M552i-B2
Thanks for the speedy reply....should power be off to the edge boards whilst testing?
ThanksLeave a comment:
Re: VIZIO M552i-B2
Anyone ever find a diagram for this model? I'm having a problem with my power supply board - it blew up chip IC 901 (which is an Infineon ice3b1565), which I'm able to find to order. Based on some discoloration on the back of the board, it seems like it may have a problem with part L801 as well, but I can't tell what it is. Looks like some kind of voltage regulator maybe - it's the very upper left part in this image https://www.ebay.com/itm/NEW-Vizio-M...9/114285632480Leave a comment:
Re: VIZIO M552i-B2
Set the meter to diode mode, if you get 000 or close to it it's short, might want to also check those caps for low ohms, expect over 100 ohms on each with meter set to 200 ohms setting, measured the same way with one meter probe on each end.Last edited by nomoresonys; 01-23-2022, 08:44 PM.Leave a comment:
Re: VIZIO M552i-B2
ca2014mp2
Can you please tell me what settings to go to, on a multimeter with no beep, to determine whether one of these is faulty or not.
I have a panel that I am advised has/maybe a similar edge board fault, but I do not know how to test it?
Many thanks, and well done on your repair.Leave a comment:
Re: VIZIO M552i-B2
Re: VIZIO M552i-B2
although your picture shows "vertical lining"... it isn't a good method to resolving issues. Get a input of a "standard test pattern" ... color bars or equivalent that is not to busy. this will do two things... provide a test of the frequencies / voltages involved in the signal along with using a signal that is not generated within the main board which may or may not have an issue.Leave a comment:
Re: VIZIO M552i-B2
Did you try cleaning and re-seatings the cables between the LCD panel and the T-CON, same for the LVDS cable.
BTW, is this the original T-CON or the replacement T-CON? You have 2 T-CON so do they react the same way?
All the board mounting screws are tightened?Leave a comment:
Re: VIZIO M552i-B2
any thoughts on this issue or should I just start testing all the resistors and caps again on the tab panel?Leave a comment:
Re: VIZIO M552i-B2
ok cap is in.. but I still have some lines running vertically from top to bottom on 100% of the screen and spaced consistently ever centermeter. Any thoughts on what might be the cause?
zoom in on picture to see the lines very clearlyLast edited by ca2014mp2; 05-03-2019, 04:25 PM.Leave a comment:
Re: VIZIO M552i-B2
Very nice driver board repair, this would have made a good youtube video, if more people knew how to fix their driver boards we could save a whole lot of them from the landfills.Leave a comment:
Re: VIZIO M552i-B2
wahhhh whhooo see the pictures..
The screen shot is with the origional t-con board that was able to withstand the short of the 10uF cap on the tab board. So this TV found in the alley was fixed for 50 cents and the help from this board. The cap is on order and will be here in a few days. Soldering was simple short is gone due to bad cap. Tv will be given to my Mr Know-it-all teenage son whom will continue to waste his life away on video games. Much thanks to all..
So I would like to know where you guys get your supplies for repair. let me know.Leave a comment:
Re: VIZIO M552i-B2
Is the shorted cap connected in parallel with other caps? Most of the time they are to get more capacitance , if it is then you can fire up for testing.
BTW, those MLCC my be handled with care removing/reinstalling, they cracked easily and shorted out.Last edited by budm; 04-27-2019, 07:06 PM.Leave a comment:
Re: VIZIO M552i-B2
What do you guys think Im at 30uF of a total of 35uF of capacitance. Do you think harm could be done with firing up the tv with that one cap off the board as I wait for my order to come in.. and BTW where do you guys get your supplies from. I use the usual ebay and amazon and would you mouser more but they have soooooo much there its kinda more difficult to find the exact part.. Let me know your thoughts..
Thanks again and I'll post some good picts by tonight..Last edited by ca2014mp2; 04-27-2019, 05:42 PM.Leave a comment:
Re: VIZIO M552i-B2
can you post a picture of the offending area for future reference?Leave a comment:
Re: VIZIO M552i-B2
yeah, looking for 10uF now. Sourcing my iPhone collection, finally Apple can be worth something.. lolLeave a comment:
Re: VIZIO M552i-B2
hopefully you can easily replace it and get a working set... yeh!Leave a comment:
Re: VIZIO M552i-B2
update c192 is a confirmed short on the tab bonding board. and these are not 35uF but 10uF capsLeave a comment:
Assuming...7 Photos -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... -
by howardc64Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot.... - Loading...
