Sometimes I come back to the QFU series TV threads, because as dodgy they are, the more I love them.
I bought mine as faulty, because I have joy in fixing stuff for myself.
It makes me a lot happier, than buying something off the shelf.
It was nice to see my picture in your post, but let me tell you my story about this TV.
I bought the TV as used, not working, however, the problem was just the flat cable, I had to jump the +12V between the mainboard and tcon. It was working fine. This was in 2020 september, so 1 year ago.
Then one day I woke up seeing my TV's stand by led blink 2 times, not turning on anymore. (2020 december)
I read about the 2 blink issue exactly in this thread, so I blew the CPU with my hot air soldering station at like 300C, low air, for 1 minutes. I then assembled the TV back together, with the stock cooler. After a few days, I did the cooler modification in Maloobs' post. It lasted for exactly 2 weeks.
Please note, that 300c upper heating without bottom heating is impossible to actually reflow the chip, especially under 1 minutes. Just a regular VGA VRAM chip needs 450c to melt the solder balls under it, and its a lot smaller and thinner.
Then I heated the chip again, this time with 215c, as I read on another forum.
The TV lasted for 1 month. Maybe important to note, that while it was working this time, I was constantly checking the heat of the heatsink with my hands while the TV was on. This will be an interesting information for later on.
(Also, note that when I first heated the chip, I also touched and modified the CPU area of the board physically several times.)
After that happened, I heated the heatsink itself to 220c without taking off the back cover of the TV, because I was lazy. The thing is, it worked. That time I also put a small fan on the heatsink and soldered it to the 3.3V line on the motherboard. I again, checked the temps many times with my hand on the heatsink, and to be honest, it was almost COLD with the fan on, so I knew that I might have fixed the overheating issue. (2021 january)
It died again after 1 month.
Since I was trying different time and temperature values, that time I again heated the heatsink on the chip with 260c for like 1-2 minutes, put the TV back on the shelf, worked again, and I did NOT touch the heatsink anymore.. (2021 february)
not until this Monday (2021 september), when I noticed that the fan on the heatsink got a bit louder, and took it off to oil it up, then put back.
Boom, after 7 months of working, the TV died again the same day I touched the heatsink of the chip.
This got me thinking.. maybe my TV actually has a bad BGA contact, rather than a bad CPU? Dunno, but I just lazily reheated the heatsink again, but after 1 day it died again.
So... today I went against my laziness, disassembled the TV, put the motherboard on the BGA machine, and properly gave it a controlled reflow with liquid flux.
Put everything back together, TV works, and now theres just one question: for how long will it work? Time will tell!
Sorry for the long post, I really wanted to share every piece of information, in case it could help other people here.
If you would ask me, why I struggle this much with this TV... my answer would be to read the first paragraph of my post!
