Olevia Syntax LT 30 HV no picture or sound
  • Lucianp
    • Jul 2009
    I have just acquired an Olevia Syntax 3LT 30 HV lcd tv.
    Until recently it was working fine, then all of a sudden, nothing. I am not sure what may have happened for it not to work - being moved etc. I only acquired it after it failed.
    During initial tests, I have power on the blue led on the front panel but nothing else. No picture and no sound. When I turn it off, the screen goes a light blue very briefly before shutdown. To me, this suggests that there is power of some sort to the screen.
    I have tried to change the source using the button on the front with no effect.
    I have tried connecting both through the Verizon set top box
    and connected directly to the wall bypassing the STB.
    Neither option gives me an inkling of picture or sound.
    Connection was via rg6 coax. I have not tried the av connections, although this is how it was set up prior to my acquiring it and it was what was used when it failed.
    I stripped the back off to check for loose connection etc. All ok.
    I would appreciate any advice on
    preliminary tests that I can perform, possible causes and resolutions. I don't want to spend money on power packs, video boards etc until I have tried all test options and am sure I am buying the right part.
    I am from the old school where we try to fix things that are broken, if at all possible. I also like to dabble and try to learn. Trying to repair something is a good way of learning especially if I can share the experience with like minded people.
    I look forward to any and all positive advice.
    Many thanks in advance.
  • Promon
    • May 2011
    Re: Olevia Syntax LT 30 HV no picture or sound
    I too have all the symptoms as described by Lucianp, but my model is Olevia 540 b11.
    I have looked at the power supply board and visually checked all capacitors and non are bulging nor corroded.
    So please if any of you kind members have any ideas please let me .
    Promon.
    • Village Electronics
      OldPro
      • 118
      Promon.
      Wouldn't it be neat if we could fix things by looking inside, finding the on switch and flipping it?
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        Promon, If you dont mind, start your own thread titled Olevia 540 b11. This will separate the problems. There, you can post pictures of your boards and people will assist you there.
        As for the orignal poster, insert clear pictures of the boards inside and we will go from there. Use "Manage Attatchments" on the posting page to do this. No inline pictures.
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
          I ordered a supposedly β€˜new' Tcon board this time, and
          06-09-2024, 10:28 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
