Samsung UE55JU6872UXXH - Lower third darker
  • bbccbb
    • Jan 2017
    • 53
    • Croatia
    Re: Samsung UE55JU6872UXXH - Lower third darker
    Some photos... regular spacer... front and back. It can be rotated 90 degrees. But I do not think I have to remove these.
    And white spacer... only front for now.
    • bbccbb
      • Jan 2017
      • 53
      • Croatia
      Well... it looks like white one is the same as the others... but only white ones are in front of the reflective sheet.
      • bbccbb
        • Jan 2017
        • 53
        • Croatia
        Originally posted by budm
        Those standoff I turn it 90 degree and pull out.
        True. Now I have to remove white plastic frame that holds reflective sheet.
        • bbccbb
          • Jan 2017
          • 53
          • Croatia
          Removed the reflective sheet, moved LED strips up and down where these connect to the vertical power strip...
          And it works now.
          Now I have a different problem... loud 50Hz buzz from the power board...
          • chrismurphy
            • May 2014
            • 251
            • australia
            just turn on the TV with the screen removed , you will see if any of the LED's are faulty
            • R_J
              • 9535
              Looks like that is what he did, look at the post above yours.
              • Diah
                • Feb 2013
                • 6363
                And it works now.
                the noise you hear because u still have bad contact at BL strips sockets. you need to re solder them all
                • bbccbb
                  • Jan 2017
                  • 53
                  • Croatia
                  #28
                  You think that I should check the sockets on the vertical power strip?
                  Or to check the socket that connects power strip with power board?
                  I still have the whole TV disassembled.
                  • Diah
                    • Feb 2013
                    • 6363
                    thought you just move sockets with hand and they power on..
                    also re soldering all sockets on the vertical BL strip even the sockets on PSU to be sure this will never happen again
                    • bbccbb
                      • Jan 2017
                      • 53
                      • Croatia
                      #30
                      No... I moved lower horizontal strips (those that did not light up) 2mm up and then down just to reconnect with vertical power strip. After doing that BL lit up.
                      Maybe I should do that with all horizontal strips.
                      I can also hear popping sounds from power board when I connect the power cable. Not turning the TV on... just plugging it into socket.
                      Popping sound originates from transformers with multiple leads, packed in black plastic, located in the middle of the board.
                      And a bit strange question... I think I can hear sound from the BL strips. 50Hz with something in the higher frequencies. How can LED produce sound?!?!
                      I'll try to record what I hear.
                      • bbccbb
                        • Jan 2017
                        • 53
                        • Croatia
                        #31
                        Ok... here are the recorded sounds.
                        First one is sound recorded at the central transformers after switching the TV off. This popping sound is audible at the moment TV receives power (stand by also).
                        The second sound is recorded near LED strips while turning the TV on from standby.
                        Sounds placed inside a .zip file.
                        • bbccbb
                          • Jan 2017
                          • 53
                          • Croatia
                          #32
                          Does this mean I have to change power board?
                            09-07-2024, 05:50 AM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 06:20 PM
