LG 42LV5500 TV - black screen, no sound, no image, no backlight
  • snme
    • Feb 2016
    • 26
    • AU
    Re: LG 42LV5500 TV - black screen, no sound, no image, no backlight
    I found the manual detailing how to conduct the T-Con RGBW test from:
    http://goihl.com/42LV5500/
    Prior to contacting badcaps, I viewed https://www.youtube.com/watch?v=nAnjxwm6ea0
    Although it had some vague aspects it led me to the above links for manuals.
    His tip as to alternative point on the T-Con to jump 3v for RGBW test, R412 south side was particularly helpful.
    Thanks for a link for reflow, but I have some trepidation and don't have confidence that a hair dryer will suffice.
    I do have a thermal gun and flux in box somewhere in the house after renovations if I can find such.
    There are so few of these mainboards available in the wild, so I don't to make a mess of the exercise.
    Last edited by snme; 08-27-2023, 09:23 PM. Reason: R412 alternative for RGBW test pattern
    • nomoresonys
      • 12276
      • U.S.
      You did not comprehend the process, he only used a hairdryer to try to help diagnose the problem, when he did the reflow, he used his hot air station, not a hairdryer.
      • snme
        • Feb 2016
        • 26
        • AU
        I was thinking about a different video, hadn't sighted your link at the time. But I suppose that I'll quickly find that a hairdryer is not designed for the purpose of burning hair off a person's head.
        Indeed I recall there would be a thermal fuse that would let go upon attempts to restrict the aperture.
        I was hesitating at the expense of a hot air tool, but now may have a budget remedy for that. I gather that set point 300 degrees C would be near the mark.
        As to warming the reverse side of that board, perhaps if of significant importance, I could park a hair dryer there. That seems safer than a glass incandescent.
        However I've noticed that multi-layer boards soak up and retain heat and would have first imagined that even heating chip side alone might suffice?
        I'm willing to hear that a better result is more likely by also heating bottom side.
        As to thermal tape, I actually have some. Whether I can find it is another issue.
        In lieu of that, or additionally, perhaps as shield a couple of slightly crumpled layers of aluminium foil surrounding the BGA with a cutout?
        Last edited by snme; 08-29-2023, 09:45 PM. Reason: Recalled hairdryer thermal fuse
        • nomoresonys
          • 12276
          • U.S.
          Here's an interesting method: https://www.youtube.com/watch?v=ZDQNOU2w_ek
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • mrtek
            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
            by mrtek
            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
            11-26-2024, 09:58 AM
          • Rozp
            70LE660U dark cloud or black screen with sound.
            by Rozp
            Hello Everyone,
            This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
            I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
            08-29-2023, 05:25 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • spice_disc
            Vizio TV M50-C1 reboot cycle and static on screen
            by spice_disc
            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
            09-08-2024, 02:37 PM
