Pn59d6500 main board question
  • Twithers
    • May 2013
    • 69
    • U. S.
    It would appear that my Samsung PN59D6500 has that bad eeprom or nand chip (I can't remember which) issue that causes the boot loop after the splash screen. I've done the usual gamut of troubleshooting steps and can't seem to come up with any other option besides replacing the main board or having a repair service replace the defective chip.
    First off, if there have been any new developments in solving the problem, I'd love to hear about it.
    If not, my primary question today is if anyone knows of an alternate main board that will function in the PN59D6500. The original main board part number is BN94-040709A but it is pretty difficult to find and very expensive if you do. I've heard of other model tv's having many n boards that will work but I can't find any actual documentation or anyone who tried a different one that worked?
    Any compatible main boards?
    Anyone have a BN94-040709A main board from a PN59D6500 they want to part with?
    Thanks.
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
