Vizio E601i
  • vbrad511
    • Feb 2015
    • 70
    Vizio E601i
    Hey folks, I originally posted this as an E701, which I know is the same generation as this 601, but I'm still having issues, and I can't find the place for the "fix". Here's a link to my original
    https://www.badcaps.net/forum/showthread.php?t=74311
    The set suffered a lightning strike a year or so back. It fried the HDMI ports, but the set still worked through other inputs, until 6 or 8 weeks ago, when the picture died. I replaced the main board, and then the tcon, and got a picture, although it seemed "out of phase", like the color was off. In reading about the 701 there's a thread
    https://www.badcaps.net/forum/showth...t=49281&page=2
    that deals with peeling the plastic frame back, disconnecting a 3/4" cable to the side boards (for testing purposes), and potentially peeling the tabs off the panel on one side or the other.
    The issue I'm having is I'm not finding the 3/4" cable, or the tabs on the sides. I've torn the tv down to the metal framework around the screen, and pulled the right side metal off, but the tabs just aren't there. Here are a few pics. Where should I be looking for the cable and tabs to be able to test this?
  • budwich
    • Jul 2015
    • 3097
    Re: Vizio E601i
    you are looking on the "WRONG SIDE" .. :-). The tabs can only be seen from the front.
    • vbrad511
      • Feb 2015
      • 70
      Re: Vizio E601i
      Just took another look. I pulled tabs on an older Samsung several years ago (first one by accident, then the rest to even things up). These are a bit narrower, so I wasn't seeing them. I'm still not seeing the 3/4 cable. I'd rather not go pulling tabs on one side or the other without determining the "guilty" side.
      And thanks for sticking with me on this round of problems, Bud.
      • budwich
        • Jul 2015
        • 3097
        Re: Vizio E601i
        it is likely that the 60's dont have a corner cable because there are no side boards. the connections that drive the side tabs are made thru the panel via the tabs at the end of the bottom edge boards and each side. The next best way to doing some "isolation testing" is to disconnect the flex ribbons that connect the edge boards at the bottom... assuming that the bottom edge boards are "two per side" (again like the 70's). Those flex ribbons are unclampable much like the tcon to panel cables so they can be disconnected without causing any issues and can then be reconnected... ie. they are NOT TABS.
        • vbrad511
          • Feb 2015
          • 70
          Re: Vizio E601i
          Yes, one cable on each side that comes out of the tcon, then two more ribbons on each side to the bottom boards. Bear with me, please. Do I pick a side and disconnect both ribbon cables on one side, then check the tv? Or just one at a time on each side?
          • budwich
            • Jul 2015
            • 3097
            Re: Vizio E601i
            basically the "ribbon" in the picture is a "U type cable". By disconnecting it (either end), you are isolating "half of the half" panel... in essence, one quarter of the panel (the outer section will no longer be "driven"). What this does, is removes the section of the board that connects and "pushes" signal up to the side of the panel via the last tab but still drives at least part of the half so the tcon is tested "better"... so if there is an issue, you might see something different in the display, depending.... maybe.
            Go from there.
              • 12178
              • U.S.
              Re: Vizio E601i
              Did/can you get a picture of the "out of phase" display that you had?
              • vbrad511
                • Feb 2015
                • 70
                Re: Vizio E601i
                I did not. The tv worked when I powered up, and the next time, no picture again (fried the new tcon). I'll get busy on it again tonight and try to keep folks posted on progress.
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • Rozp
                  70LE660U dark cloud or black screen with sound.
                  by Rozp
                  Hello Everyone,
                  This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                  I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                  08-29-2023, 05:25 PM
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • frannyjunk
                  Vizio M60-C3 left side of screen + a couple other areas dim
                  by frannyjunk
                  My Vizio M60-C3 was dead. No power, no lights. Just nothing. So I took the back cover off and noticed 4 bulging caps on the power supply board, so I replaced them (green low esr capacitors in the picture). The tv now works! But there are some areas that look dim (see picture). In particular, the left side has a dim band. I know that the led strips run horizontal, yet this band is vertical. Could it be that the led driver board is bad? Could the blown caps have taken out the led driver board? Or is this just a coincidence that every left side led on each strip just went out?...
                  11-10-2021, 08:09 PM
