sony APS-277 Atypical failure
  • itelite
    • Aug 2016
    • 124
    I have an APS-277 power supply that is completely dead on the secondary side. No STB, no anything.
    170 at the primary caps. Doesn't not appear to be any transistors or diodes shorted.
    I have found R6201 to be open. A 10ohm 1/2w. Based on continuity testing it appears to be across the primary caps (which feels strange). Cannot seem to find a schematic. I found sony_ge4a_cxa3809am_fa7700n_ba2901sf_sch.pdf which seems to be similar but not quite there.
    Does it make sense for that 10ohm 1/2W to be running across those caps? Seems awful small if its meant to drain those big caps.
    Maybe something going on with IC6201? ::Update:: IC6201 shorted D-S. Removed, above resistor connections no longer relevant. Guess ill replace this thing and see what happens.
  • Unspun01
    • Jun 2011
    • 349
    Re: sony APS-277 Atypical failure
    I don't know what TV model you have but see if this thread for a SONY NSX-40GT1 with APS-277 power supply helps you:
    www.badcaps.net/forum/showthread.php?t=52274
    • itelite
      • Aug 2016
      • 124
      Got it. IC6201 Shorted - opened up R6201. Took both from donor board and TV is alive again. Guess i just had to think out loud a little. Hope this thread helps the next guy.
      • Unspun01
        • Jun 2011
        • 349
        To help others, please let us know what is the resistance value of R6201 and the part number marking on IC6201 that you replaced...
        • itelite
          • Aug 2016
          • 124
          10 ohm, blown wide open.
          MIP2H2 7 pin DIP
            R6201 is fusible flame proof resistor it is used for feeding the Voltage from the main cap to the Standby power supply section, it will blow open if the STBY SMPS IC shorted out.
            https://www.shopjimmy.com/sony-1-474...ge7-board.htm#
            • delpiero3
              Sony Vaio SVS MBX-261 board failure
              by delpiero3
              Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
              Nevertheless, let's say, i don't come as a total beginner.
              I have this old laptop, which suit perfectly my needs, with the...
              10-29-2024, 06:16 AM
            • Carlos#2003%
              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
              by Carlos#2003%
              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
              02-15-2024, 07:52 PM
            • dkneyle
              Sony KDL-46HX850 Can't upgrade/update firmware
              by dkneyle
              Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
              Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
              09-25-2024, 10:44 PM
              Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
              This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 05:27 AM
              Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
              This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
              09-06-2024, 05:30 AM
