lg 60pz550 black screen, no power, etc
  • legonch
    • Feb 2019
    • 49
    Re: lg 60pz550 black screen, no power, etc
    Okay, so I tested the zsus thoroughly. The fuse ohms out. however the fuse to the board doesnt. multiple locations on the board to not ohm out. Most if not all mosfets are grounded. Multiple capacitors are grounded. Im seeing basically half of the board with not register any ohms at all.
    Am I correct in thinking this board is totally gone?
    • legonch
      • Feb 2019
      • 49
      Well, more news. Yesterday I had the proper volts on both sus connectors. Today I do not.
      The lowest fuse reads 120.8 volts. The other two fuses on the power board read 63
      What does this mean?
      The voltage at the sus connectors reads initially, but zeros out in a second. Exact same thing at both connectors Like there is a voltage, and then it bleeds away.
      Power board suspect here?
      • Unspun01
        • Jun 2011
        • 341
        "The fuse ohms out"??? This slang means exactly nothing. It means even less to anyone who does not speak English well. Don't use this phrase - remove it from your vocabulary actually. Nobody should ever use this junk ambiguous phrase. Use the word "continuity". The fuse has continuity or the fuse does not have continuity is immediately clear to anyone reading this.
        I told you to check the 4633 IGBTs and their 7371 drivers on the bottom of the board. If one of these is shorted out, then you could measure a short to ground at multiple locations. You should try removing one "shorted" IGBT transistor at a time until therecently are no more left. Many of your other "shorts" may disappear with removal of the bad components. I don't recall but there may be about 6 of them.
        This is usually a very repairable board. If you remove/isolate the bad components you have high chance of repair. But listen to advice on here and do not rush.
        • legonch
          • Feb 2019
          • 49
          Dumb question, with the boards installed on the tv, cables unplugged, should you get continuity on every solder point if everything is in working order? Im testing the z and y sus boards, and the power board, and finding about half of the board there is no continutity.
          About half of the 7371s have continuity on two pins, but not on the single pin by its self. The other 7371s have no continuity at all, this is on the zsus board.
          • Unspun01
            • Jun 2011
            • 341
            legonch:
            How are you measuring things? It sounds like you are trying to measure continuity from all components to the grounded TV chassis.
            If you are measuring for short circuits from TV chassis to ZSUS and YSUS boards, there are MANY common ground points. If you do not know which ones are intentionally grounded, you will not be able to troubleshoot this board.
            Please work on ONE BOARD AT A TIME, then proceed to the next board.
            I don't think your problem is power board so leave it out for now.
            Start with YSUS or ZSUS. Make it clear to us which board you are working on and do not lump together your observations for both boards since we do not know what you are doing.
            Measure each of the 3-pin 4633 IGBTs. I've asked you to do this a few times and you still have not done this. I'm still waiting for your results.
            There should be NO short circuits between pins 1-2, 2-3 or 1-3 for any of the IGBTs.
            Some 3-pin diodes will have pins 1 and 3 tied together on-board but pin 2 should not measure as a short to pins 1 or 3. Diodes may measure a short in-circuit but may not be the issue if they are connected to a shorted IGBT.
            You still have not said if the fuses are good? Are the fuses good or not?
            • legonch
              • Feb 2019
              • 49
              ok, thanks. this is the zsus board. I took it off the tv, bench tested it. nothing attached to it.
              There are three rows of these of these igbts. looking from the front, far left row, installed on a silver piece, no continuity on any of the four diodes.
              Middle row of these under a long black piece, i get continuity on pins 1 and 3 for the top 7, the bottom three, i get no continuity
              the last row, installed on a silver piece, no continuity to any of the six installed
              I have continuity through the fuse, reading .3 ohms.
              will wait for a reply before testing ysus board. Thank you for your help
              • Unspun01
                • Jun 2011
                • 341
                I attached a markup photo of the bottom of the ZSUS board. I highlighted in RED each IGBT transistor and their gate resistors, and their gate drivers.
                The red highlighting in my photo is:
                Upper right area (the 4 parts are attached to small silver heatsink)
                Lower left area (the 4 parts are attached to larger silver heatsink)
                Lower middle area (the 3 parts are attached to large black heatsink)
                I did not highlight the diodes on the heatsinks.
                From your observations:
                1) The 4 diodes look ok.
                2a) The top 7 parts you measured are diodes. Pins 1-3 are physically connected together for each of them. If you have no short between pin 2 and 1-3 they are ok.
                2b) The lower 3 IGBTs look ok if you do not measure short-circuit from 1-2, 2-3, 1-3.
                3) The 3 IGBTs look ok if no continuity on all 3.
                4) The fuse looks ok.
                I think your ZSUS may be ok. Can you test between pins 2-3 on the white topside connector P102?
                If you do not measure short-circuit here, then let's move on to the YSUS.
                • legonch
                  • Feb 2019
                  • 49
                  okay, ill attach a pic of my tests, hope you can see it. I do not register continuity between pins 2 and 3 on the p102
                  • legonch
                    • Feb 2019
                    • 49
                    Here are my tests on the ysus board.
                    • legonch
                      • Feb 2019
                      • 49
                      bump
                      • Unspun01
                        • Jun 2011
                        • 341
                        Please see attached photos for YSUS checks to complete.
                        Unfortunately, your tests are not clear to me since I do not know what or how your are measuring.
                        On top side, measure the 3 fuses FS101, FS102, FS103 for continuity. You already said FS102 is good I think?
                        Also, check for short/continuity between GND and ANY of +5V, +VA, +VS on connector P113.
                        RED:
                        On the bottom side, please check for short/continuity in all of the 3-PIN devices highlighted. If you measure a short in any combination 1-2, 2-3, 1-3 then the component may be bad.
                        The gate resistors highlighted should be low resistance values. If they are high resistance, or "open", then they are likely bad.
                        YELLOW:
                        The devices in yellow are diodes and rarely fail, but can measure shorted if an associated IGBT is shorted. If you measure a short on any of these, double-check the RED highlighted devices.
                        PINK:
                        These coils can develop bad solder connections. If they look dark, or burned, or loose, then re-solder with lots of non-acid flux and leaded solder.
                        • legonch
                          • Feb 2019
                          • 49
                          continuity between all of these three fuses
                          No continuity between any of these pins
                          All the red highlighted items, there is no shorts detected. The resistors all have continuity, .15 ohms
                          Pink highlighted items show continuity.
                          • Unspun01
                            • Jun 2011
                            • 341
                            Well, it looks like you didn't measure shorts on the ZSUS, or YSUS boards.
                            Let's go back to power board.
                            1) TV unplugged.
                            2) Connect everything except power wires (from power board to YSUS and from power board to ZSUS)
                            3) Place black multimeter lead on TV metal chassis and leave it connectd.
                            4) Plug TV in and turn on.
                            5) Measure voltage with red probe at 5V on power supply.
                            6) Measure voltage with red probe at VA on power supply.
                            7) Measure voltage with red probe at VS on power supply.
                            You may have to turn TV off and back on again to complete the measurements. We want to measure the voltages AS YOU TURN THE TV ON... We want to see if the voltages come up, and if they come up, what are they? and if any voltages do not come up.
                            Write back here.
                            • legonch
                              • Feb 2019
                              • 49
                              Okay. power board installed. no flat cables attached anywhere. Do not get the red light in front of the tv, remote doesnt work
                              Plugging in the tv while reading the 5v pin shows an initial voltage of 3.7, then drops to Zero
                              Reading the Va pin, i get voltage numbers all over the place. 137volts to 0. Meter voltage is constantly moving. Same readings while plugged in, and while powering up.
                              The bottom Vs pins register 0 volts.
                              • budwich
                                • Jul 2015
                                • 3097
                                there is something "strange" about "All the red highlighted items, there is no shorts detected. The resistors all have continuity, .15 ohms".... is the ".15 ohms" a typo or that the measurement? Have you looked closely at those resistor to see if there is any label on them to indicate value.... the value you list is basically a "short"... or at best, the resistance of the test wires.
                                • legonch
                                  • Feb 2019
                                  • 49
                                  the .15 ohms isnt a typo. Thats what all of them read. All the same, pretty much exactly
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    hmmmm.... I would expect any kind of resistor in / around any FET's or "switch transistors" to be in the 5-20 ohm range.... and I personally have never seen a resistor below 1 ohm. Further, most meters unless they are "really good", would measure the reistance of the test leads in fractions of an ohm.... meaning that you potentially ARE seeing a short / near short.
                                    • legonch
                                      • Feb 2019
                                      • 49
                                      Ill retest and publish the results.
                                      Im leaning twoards the power supply board having an issue. I dont get any voltages at the connectors to either sus board
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        some time shut down happens pretty fast... depending on conditions and how you are monitoring things.
                                        • legonch
                                          • Feb 2019
                                          • 49
                                          Okay, did new testing. I got readings from 13.8 to 15.3 ohms. I apologize for the misprint above.
                                          Anything else I should test?
                                          • grimacelord
                                            HP 15-EH1070wm - Black Screen With Power LED.
                                            by grimacelord
                                            I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                                            First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                                            01-28-2023, 10:50 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • rybby
                                            Acer Aspire 5 A515-51 power on but black screen
                                            by rybby
                                            I have an acer aspire 5 a515-51 that turns on but has a black screen.
                                            This laptop has the same symptoms as https://www.badcaps.net/forum/showth...er+aspire+a515, however mine is a different model Acer Aspire A515-51 (without the 'G'). There is no onboard ram on this laptop.
                                            Description of the problem is the same: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts...
                                            06-16-2023, 09:41 AM
                                          • burntonnerings
                                            Acer K272HUL blue power light but black screen, power supply is ok
                                            by burntonnerings
                                            Have had two Acer K272HUL monitors die with the same symptoms:
                                            - Blue power light is illuminated while the monitor is plugged in
                                            - Black screen (no splash screen, etc.)
                                            - Power button doesn't do anything
                                            Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
                                            Power supply voltages are fine.
                                            There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
                                            Anyone have any ideas?...
                                            12-09-2023, 10:22 PM
                                          • samolo75
                                            Asus Laptop GL702VS black screen power LED on
                                            by samolo75
                                            I am fighting with this laptop and I am suspecting of the GPU, but it would be great to know your opinion.
                                            The laptop originally does show black screen (no back light) but the power button LED turn on and off when pressing it.
                                            I did the next trouble shooting with no changes
                                            - Disconnected the battery and try just with the power supply
                                            - Disconnected all power sources, even the CMOS battery and held the power button for 40sec.
                                            - Disconnected hardrives
                                            - Deplaced the RAM
                                            - Disconnected the Wifi module
                                            - I connected a external monitor to the...
                                            03-31-2021, 03:16 PM
