Tcl 55S405 bad T-con?
  • mikalcarbine
    • Sep 2012
    • 7
    My TCL just went on the fritz last night, purchased November 2017. From what I've been reading I think this is the T-con board but would like others' opinions or suggestions.
    Boards physically look OK, only two caps on the power supply and they look fine, voltages coming off power supply with load look OK. The voltage pins are poorly labeled, I'll need to spend a little extra time taking measurements before ordering anything
    Here's a video, let me know if the link doesn't work
    https://photos.app.goo.gl/BKQRS9mhvMiCJELw5
  • mikalcarbine
    • Sep 2012
    • 7
    Re: Tcl 55S405 bad T-con?
    Future reference for anyone who finds this, replaced the T-con and all is working normal now.
      • 12276
      • U.S.
      Thanks Mikalcarbine, good example why you shouldn't jump to conclusion of bad panel because it can be hard to tell, can be just the tcon as in your case.
      • DeatRaton
        Gio
        • Oct 2019
        • 36
        I'm assuming I have a bad tcon board as well. I have a line going down the screen, no cracks, and the film at the bottom of the TV seem to be in good shape, I touch all of them and nothing changes. The line remains solid. Can someone confirm tcon might be my problem?
        • neilc6
          • Nov 2015
          • 1550
          Solid lines are usually panel problems and not the tcon.
          • celloyd
            • Dec 2019
            • 8
            Can you share what your problem was that caused you to replace the tcon board? My TCL would turn on and show the screen and sometimes not. I could unplug and plug back in and it would work but eventually the picture never came back no matter what i did. I could always hear the sounds when I used the remote, just no picture. I was planning to buy a repair kit and replace the whole works but if I don't have to, that would be even better. Any trouble shooting help would be GREATLY APPRECIATED!
              • 12276
              • U.S.
              If the backlights are not coming on, shine a flashlight at the screen look closely maybe hit the menu button on tv or remote, see if you can see text or anything on screen.
              • celloyd
                • Dec 2019
                • 8
                I'll need to check when I get home but I'm pretty sure the screen lights up, just don't see the "wallpaper" of the start page. Shows me a dark grey screen. I also read where if you let it sit for an hour, you might have luck with a reset. I have not tried that yet, either.
                  • 12276
                  • U.S.
                  Also test the fuse on tcon, should be about 12 volts on each side, black negative test probe on chassis/metal panel, red probe on each side.
                  • celloyd
                    • Dec 2019
                    • 8
                    Also test the fuse on tcon, should be about 12 volts on each side, black test probe on chassis/metal panel, red probe on each side.
                    Thanks!! I will hopefully get to this tonight and report back.
                    • celloyd
                      • Dec 2019
                      • 8
                      Okay, not sure where the fuse is? Also, it needs to be plugged in to test volts, correct?
                        • 12276
                        • U.S.
                        Yep plug in hit power see if it's there, fuse should be close to where the cable comes in from the mainboard, on tcon, should be labeled starting with F, like F1 or sum such.
                        • celloyd
                          • Dec 2019
                          • 8
                          I'd like to post a pic and have someone point it out for me? My old eyes are not seeing it.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            F1
                            • celloyd
                              • Dec 2019
                              • 8
                              Originally posted by diif
                              F1
                              Thanks!! So I tested it, reads 16v on one side and 0 on the other assuming I am doing it correctly. So tiny that it's hard to know if I'm hitting the right spot. Does this sound reasonable and if so, where do I go from here; what is this telling me?
                                If one end of the fuse shows 0V that means the fuse has blown.
                                • celloyd
                                  • Dec 2019
                                  • 8
                                  So...replace the TCON board and I'm good to go? Do I need to further investigate the cause of the blown fuse? Hate to replace this board only to have the same issue happen again.
                                    Since you do not have the schematic of the T-CON board, you should start checking the RESISTANCE of the caps on that T-CON board to see if any one of them shows very low resistance (<10 Ohms) or not, if you find shorts the disconnect the cables between T-CON and the LCD panel to see if the shorts will go sway or not.
                                    • Louis82
                                      • Feb 2012
                                      • 240
                                      Hi Budm,
                                      Have you guys been able to find what is the cap or component that fails in this T-CON board? I have checked all caps and no short on caps or IC's.
                                      Any suggestion or update on this TCON board repair?
                                      Thanks!
                                      • kca
                                        by kca
                                        Hello all ~
                                        08-31-2025, 06:38 AM
                                      • x_orange90_x
                                        TCL 50S535 bad tcon or panel issue?
                                        by x_orange90_x
                                        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                        03-29-2025, 11:02 PM
                                      • advant
                                        by advant
                                        02-03-2020, 12:25 AM
                                      • Hakuu
                                        by Hakuu
                                        Hi There,
                                        More Details
                                        TV Model - LG OLED77G1PUA
                                        07-12-2023, 02:37 PM
                                      • netgearnetgear
                                        TCL 43S423 TCON OR PANEL FAULTY???
                                        by netgearnetgear
                                        Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                        08-20-2025, 06:04 PM
