Sansui SLED4280
  • macsnjets
    • Oct 2017
    • 5
    Sansui SLED4280
    I'm kind of new to tv troubleshooting. I fixed a few but I have a sansui 42” LED tv in which the backlight shuts down whenever the backlight is any higher than 2 on the settings. This tv has a separate LED driver and inverter board. All the caps on the driver board are not bulged. I also think I read somewhere that bad led's could be the culprit but all seem to light up normal judging by the screen's appearance. Thanks in advance to anyone that may have some troubleshooting tips for me.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8203
    Re: Sansui SLED4280
    it's bad led(s) in the back light. They can fail like that.
    • macsnjets
      • Oct 2017
      • 5
      Re: Sansui SLED4280
      Is there anyway to isolate which strip? There are four leads which head to the strips. If I were to take one off at a time and turn the backlight intensity back up would that work or is there a better way to isolate the bad led or leds? Would a visual check indicate the bad led if I open up the panel?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8203
        Re: Sansui SLED4280
        Measure the voltages on each LED string until it fails. Unfortunately it is a bit hard to figure out what LED failed, since it is working fine until it gets warm. Then you know in what string the bad LED is. Then you'd have to test either each LED or a LED strip individually with a variable CV CC lab power supply.
        • osrex
          LED DRIVER KEEPS DYING
          by osrex
          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
          i have no datasheet at all for the LED lights, all i have is its length.
          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
          05-05-2025, 03:36 PM
        • charif
          Audio Driver for Thomson P14C4BK128
          by charif
          Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
          I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
          The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
          Here are the details:
          • Model: Thomson P14C4BK128
          • Operating System: Windows 10 64-bit
          If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
          Thanks in advance for your help!
          04-30-2025, 05:41 PM
        • bohaboha
          how to install gl usb2.0 uvc camera device driver on windows 10
          by bohaboha
          Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
          but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
          any help?
          01-26-2025, 08:33 PM
        • ShadowAi
          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
          by ShadowAi
          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
          03-15-2024, 10:46 AM
        • howardc64
          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
          by howardc64
          Problem
          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
          Model & Board Pics
          Conflicting Spec
          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
          https://www.shopjimmy.com/vizio-gj-2k1...
          10-10-2024, 01:16 PM
