LG 50PX990 Plasma Powering itself off
  • Daveatfernie
    • Nov 2013
    • 70
    Good morning
    I have an intermittent 50 inch PX990 plasma TV which I think has electronics based on the 50PK990.
    Recently it's started turning itself off after being on for 10-15 minutes and gets to the point where it will only stay on for a few minutes before turning off.
    When it turns off and you try to turn it on you can hear the relays clicking in but it clicks off immediately. Leaving it for a few minutes (perhaps to cool or discharge) allows the TV to be powered up for a little while.
    I've repaired quite a few LCDs previously but the back of a plasma is a different kettle of fish. I had a look at the guides from the links but none of them seemed to be for an intermittent fault as mine is.
    I've tried to take clear pics but if you need closeups of anything please let me know.
    Thanks in advance
  • Daveatfernie
    • Nov 2013
    • 70
    Re: LG 50PX990 Plasma Powering itself off
    I managed to find the supply voltages sticker in the chassis so I'll have a look tonight to see what they look like compared to the PSU output.
    There seems to be a wealth of spare boards if required on e-bay but I'd prefer to not have the board in a skip.
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Based on my experience with similar LG boards in both plasma and LCD TVs, I'm going to guess that you have failing connections on the processor on the main board. It's going to need to be professionally re-balled in order to remedy the problem.
      • Wilderone
        • May 2018
        • 76
        Check for cold solder on back of power supply. Common on these power supply boards & with these symptoms.
        • Daveatfernie
          • Nov 2013
          • 70
          Thanks for the replies,
          I'll check the back of the PSU board. I could look to get the processor reballed as we have pretty good BGA reflow capability at work. Certainly a couple of things I can check to be going on with.
          It may well be though that if I find nothing wrong with the PSU board I'll see if there are any second user boards I can swap in. I'll have a chat to the lads and see if we have any suitable stencils.
          Thanks again
          • Daveatfernie
            • Nov 2013
            • 70
            Apologies, Is it the board with the FPGA I'd replace or the board with the XD processing chip on it (the BGA with the two memory IC's next to it)
            One appears to be the control board (50R1X_CTRL) the other (the one with the FPGA) is I assume is for OSD and test signal generation?
            • Wilderone
              • May 2018
              • 76
              I would be having a look at the back of the power supply first, only take you a few minutes to unscrew it & have a look for cold solder joints, then hit them with a soldering iron.
              • Wilderone
                • May 2018
                • 76
                The Mainboard is the one with the large black heatsink, Inputs, HDMI etc.
                • Daveatfernie
                  • Nov 2013
                  • 70
                  Only just managed to do some investigation today. Surely enough on the back of the PSU board there's a few cold joints around the transformers. I'll refit the board tonight and test it. If this ends up being the culprit I'll post pics so others can see where the problem was. Definitely cracking around the transformer pin so likely as not to cause a power loss under thermal stress.
                  I was quite surprised to see how the board has discoloured around the transformer. Do the boards discolour a lot on their own or are the components really running that hot?
                  • Wilderone
                    • May 2018
                    • 76
                    Just heat stress mate, you can imagine how long & many times that board has heated up & cooled over it's lifetime.
                    Have done a few of these now, nice simple fix.
                    • Daveatfernie
                      • Nov 2013
                      • 70
                      Seemingly sorted. Wish all repairs were as straight forward as this.
                      I've attached a couple of photos in case people don't know what they're looking for with a dry joint, cold joint, stressed joint.
                      These pins were the main culprits for me although I reflowed the whole set of pins on the board.
                      Thanks again for the help
                      • Wilderone
                        • May 2018
                        • 76
                        Well done, your welcome.
                        • DancingElectron
                          Samsung Plasma PN51F5300 not turning on
                          by DancingElectron
                          Product: Samsung Plasma TV (PN51F5300)
                          Initial symptoms:
                          In-laws were downstairs watching tv when they heard a pop and the screen went out.
                          When resetting power and turning on again, front light blinks red a few seconds and goes out: tv is otherwise unresponsive until power is cycled again.
                          Initial investigation: Remove back from Plasma TV, armed with DMM.
                          No obvious capacitor bulging on any visible boards.
                          Power connected, turned on: green LED on main board repeats a pattern of short-long (1 second total) on, one second off. Repeats five times....
                          09-08-2020, 08:30 PM
                        • theone111
                          by theone111
                          3. Problem: TV shuts down
                          07-22-2024, 10:36 AM
                        • protocold
                          MacBook Pro 15" 2010 820-2850 intermittent charging
                          by protocold
                          I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
                          I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
                          when it is not intermittent:
                          PPVBAT_G3H_CHGR_R is 12.07v
                          when it is intermittent:
                          When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
                          when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
                          data line on the battery...
                          07-25-2025, 08:18 PM
                        • valvashon
                          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                          by valvashon
                          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                          11-24-2024, 12:08 PM
                        • Lisadk
                          LG 55 UF6450-AU tv no audio,Flickering screen intermittent, not turning on.
                          by Lisadk
                          I have a Lg 55 uf6450-UA tv with no audio, no display, a flickering screen with a red light that blinking 3 times on the display when I power the unit on. This occurs temporarily when the tv has been unplugged for a while. The voltages on the power supply board at this time on p201 connector -pin1-3.3vdc pwr-on, pin 3-0 Grd, pin 5- 13.2,vdc pin 7-13.2vdc
                          pin 9-0v Gnd, pin 11-3.4vdc. All the readings are steady on the connector.
                          At the Test point 13.2v a steady 13.2vdcvolts. The voltages at P 801 the Led connector read LED+ 154vdc, LED-23vdc, led+ 319-346vdc not steady, led- 0v. I...
                          12-06-2019, 09:01 AM
