Samsung UN40J5200AFXZA Color Issues
  • MvZiC MaN
    • Apr 2017
    • 19
    Picked up this TV at the curb. Everything seems to work flawlessly except a sleight color issue. i was hoping to be able to repair it and replace my current one.
    Its hard to see in the pictures.
    Note the sleight green hue around the flame on the top right of the 2nd picture.
    https://www.badcaps.net/forum/attach...7&d=1548122359
    https://www.badcaps.net/forum/attach...8&d=1548122359
    additional photos are of the Power and Motherboards
    https://www.badcaps.net/forum/attach...1&d=1548122359
  • cheeky2
    • Dec 2012
    • 337
    Re: Samsung UN40J5200AFXZA Color Issues
    I had an identical issue actually worse than yours on a Samsung UE48J5200AK model.
    After purchasing a cheap tcon board for it it didn't resolve issue. So replaced main board and resolved issue. Then found two flash ics on the boards. I cloned the new board flash ics and programmed them onto the old board. The old main board was then repaired and now listed back on ebay.
    So in conclusion you have firmware corruption on the eeprom ic 24c256 and flash ic 25q40.
    • MvZiC MaN
      • Apr 2017
      • 19
      I dont have the ability to flash an eeproom atm. But it looks like the Mainboard for this tv isnt very pricy so ill start with replacing that and hope that fixes it. Thanks for the info!
        • 12116
        • U.S.
        Did you try a firmware update/reapply?
        • MvZiC MaN
          • Apr 2017
          • 19
          Ya know, Honestly I didnt even really think about that. I will give that a try when i get off work tonight. Is that something i can do through te tv? or do i need to use my PC and Update via USB?
            • 12116
            • U.S.
            Came up with this, not exactly sure if it's right or not tho: https://www.samsung.com/latin_en/sup...N40J5200AFXZA/
            • MvZiC MaN
              • Apr 2017
              • 19
              Heres a couple better pics. Note the ring around the "HOME" icon.
              https://www.badcaps.net/forum/attach...7&d=1548651350
              https://www.badcaps.net/forum/attach...8&d=1548651350
              Still doing the same after running the Firmware update. So im assuming im gonna have to replace the MoBo?
              • jjanssen7
                • Nov 2012
                • 252
                I have the same model tv with a similar problem and have tried a few main boards which all display the same. On my tv the tcon is integrated with the panel. I believe the problem is on the tcon. The UE48J5200AK mentioned above has a separate tcon so his experience may be different than ours.
                  • 12116
                  • U.S.
                  This tcon may be compatible, I would call shopjimmy and see if they can verify compatibility or not. https://www.shopjimmy.com/samsung-bn...-con-board.htm
                    • 12116
                    • U.S.
                    This may be a match. https://www.ebay.com/itm/SAMSUNG-40-...gAAOSwM4xXZh~F
                    Check the sticker on your tcon for BN95-01940B
                      • 12116
                      • U.S.
                      Those are for models without integrated tcons of course.
                      • MvZiC MaN
                        • Apr 2017
                        • 19
                        Here is the back of my TV. I think mine has an integrated Tcon.
                        https://www.badcaps.net/forum/attach...5&d=1548702341
                          • 12116
                          • U.S.
                          Think so, thinking those I listed are probably for older tvs.
                            09-07-2024, 05:50 AM
                          • L36
                            MSI GE 65 - 9SF - Bad flash issue
                            by L36
                            Hi All,
                            Having an issue with a bricked MSI GE65 - Model 9SF. Bricked BIOS, did not do a full BIOS dump backup including ME region (rookie mistake). Resorted using to the latest BIOS available from MSI to flash the BIOS via CH341A for this laptop.
                            Problem - I initially flashed a ME update that came out for this laptop as a separate update. Thus, before bricking the laptop the ME version was 12.0.94.2380. PMC version 300.2.11.1025 on the system. The MSI latest BIOS I'm trying to flash back via CH341A contains ME version 12.0.40.1433. PCM version 300.2.11.1024.
                            The...
                            02-27-2024, 10:11 AM
                          • vincentedel
                            Samsung SyncMaster 740n Phase Control Issue
                            by vincentedel
                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                            04-22-2025, 12:33 AM
                          • Manucsl
                            QE65Q800TATXXC Samsung TV Issue
                            by Manucsl
                            Hello.
                            My TV is a QE65Q800TATXXC Samsung TV.
                            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                            Any ideas to check would be very appreciated 😊
                            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                            02-19-2025, 07:47 AM
                          • Deeloc
                            How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
                            by Deeloc
                            I have a 1tb WALRAM SSD (Photo)
                            Controller SM2259XT2G (photo)
                            Samsung memory (photo):
                            Part Number K9DVGB8J1B DCK0
                            Name V-NAND V6
                            Type TLC
                            The SSD itself is detected as 1gb, but is not initialized.
                            There is a Sata to USB adapter
                            A lot of SMI MPTool, did not flash it. compare flash fail (17)
                            K9DVGB8J1B is not listed anywhere
                            What to flash?​...
                            06-05-2024, 08:32 AM
