DSE GE6987 LCD TV main board (303C3393073) - DDR SDRAM voltage
  • japlytic
    • Oct 2005
    • 2086
    This board is almost identical to the Haier 55E3500, and in both controllers, DDR SDRAM is integrated.
    When connected to a power supply and LCD controller tester, a brief "Loading" message appeared before the picture snowed out, but it did start up OK under unknown circumstances.
    An analysis of the circuit revealed that the DDR 1.8V regulator was set for 1.5V (270R between regulator Adjust-Output and 56R between regulator Adjust-GND; 120R between Adjust-GND sets output voltage to 1.8V); even though the Haier circuit uses the MSD3393 (ATSC) as its controller, the GE6987 uses the MSD6306 (DVB) with the same pinout.
    Searching for sets which used the MSD6306 (and a block diagram of this IC) revealed that some use a 1.5V DDR voltage while others used 1.8V; the absolute maximum voltage for DDR3 (1.5V +/- 0.075V) SDRAM is 1.975V, so changing the voltage of the DDR regulator to 1.8V with a 240R resistor added between Adjust-Output (even though there was a minor risk of catastrophic failure) resulted in consistent startup of this board without excessive current draw.
  • capwizard
    • Jun 2016
    • 1991
    Re: DSE GE6987 LCD TV main board (303C3393073) - DDR SDRAM voltage
    May I ask?
    What is the difference between MSD6306 and MSD3393LUM? is that because V-Chip Control or integrated Internet or Android system?
    Study MSD3393LUM
    https://www.badcaps.net/forum/showthread.php?t=60902
    • japlytic
      • Oct 2005
      • 2086
      Originally posted by capwizard
      What is the difference between MSD6306 and MSD3393LUM?https://www.badcaps.net/forum/showthread.php?t=60902
      The MSD6306 is DVB while the MSD3393 is ATSC.
      • capwizard
        • Jun 2016
        • 1991
        oh Thank you.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
        • artvandalai
          Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
          by artvandalai
          This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
          The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
          11-05-2024, 07:38 AM
