LG 55LV5500 TV - Has power No backlight No Sound No picture
  • TubeJunkie
    • Oct 2012
    • 107
    I picked up this TV from the recycle center . LG 55LV5500-UA. When powered on, the power indicator goes from red to white. It has no backlights and no sound. I tried doing the flashlight test and didn't see anything. I took some voltage readings with power on. Mere set to DC volts, negative lead on Metal tv chassis. See pic:
    P201(supplies tuner/input board) pins aren't label, so from top to bottom:
    Pin 1- 0 vdc
    Pin 2. 12.02 vdc
    Pin 3. 12.02 vdc
    Pin 4. 12.02
    Pin 5. 0
    Pin 6. 0
    Pin 7. 3.5 vdc
    Pin 8 3.5
    Pin 9. 0
    Pin 10. 0
    Pin 11. 24.8 vdc
    Pin 12. 3.4 vdc
    Re: LG 55LV5500 TV - Has power No backlight No Sound No picture
    Please do not duplicate the request for help, you already has the thread for this one.
    https://www.badcaps.net/forum/showthread.php?t=74124
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Based on my experience with these and other models that utilize the same basic main board, I'd say you almost certainly have bad connections on the main processor due to failed solder on that BGA chip. It's extremely common with this model and results in no HDMI, freezing up on the splash screen, or turning on with no backlights as you are experiencing. It can often be remedied by a reflow of the main board temporarily but the only real fix is to re-ball the processor.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • jord4231
        Toshiba 37AV500A Regza TV good power supply no sound no picture
        by jord4231
        Hi Everyone,
        I'm working on a Toshiba 37AV500A Regza TV.
        The issue:
        TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
        The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
        I checked the PSU voltages and everything looked good.
        No bulging caps or signs of heat.
        24v aud = 24.41v
        12v = 11.98v
        5v = 5.062
        p_o/f = Goes high...
        03-29-2022, 09:21 PM
