Sony Memory Stick formatter tool (for KDL-26U4000)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. This is going to be slightly embarrassing, since I work in an "authorized" Sony center, yet here I am asking for help in various third-party places As I always said, there's no such thing as "perfect anything" and nobody can claim they know everything, so help is always welcome as long as it gets the job done. Let's cut to the chase:
    KDL-26U400 has a strange issue: wide purple vertical dotted bar shows up at the left side after power-on. I thought it's a panel issue, but then I reconsidered it: it goes away when you change the source, but you can't change the source back to TV and it doesn't detect any channels at all. There's also no factory reset option in the user menu (don't know if it's bugged out and it disappeared or it didn't have such thing from the factory).
    This makes me believe it's a software issue. I logged onto our Sony platform and located some firmware, but here's the embarrassing part: I can't find a "formatter tool" as they call it. Apparently sticking the memory stick into it is not enough (we're talking about Sony's proprietary "memory stick" card and not an actual USB stick, since it doesn't have USB). It first needs to be formatted with some special tool to get the TV to recognize it, otherwise it just sits there and does nothing despite having the firmware file on it. The documentation does indeed provide a link to what software would've been used back in the day, but with this being so old it no longer works...any ideas at this point? Any Sony aficionados out there who could lend a hand....told you it's embarrassing: Sony center doesn't have Sony tools...TBH, I don't even have a memory stick handy - will have to hunt for one...WHAT KIND OF PLACE IS THIS ?! Cheers guys. Any help is always welcome.
    Wattevah...
  • CapLeaker
    Leaking Member
    • 8352
    Re: Sony Memory Stick formatter tool (for KDL-26U4000)
    I agree with you there. It's not the panel, it's on the main board. But it still could be faulty hard ware on the main board. Can we see some clear pics of the main board?
    try this to factory reset: https://www.youtube.com/watch?v=1J6w8cHRKu0
    • CapLeaker
      Leaking Member
      • 8352
      maybe a bad eeprom or eeprom flash? Maybe also worth checking out.
        SONY Memory Stick® Formatter Software
        https://www.sony.com/electronics/sup...loads/W0002860
        or just search for MSFMTINST250.EXE
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          I haven't taken it apart yet because I was hoping I'd be able to fix it "externally" for now, so the best I can do ATM just to keep the ball rolling is to provide a snippet from the service manual. I'm expecting the part encircled to be of interest. Also, the board model is A-1545-603-A if you can find anything on it (again, according to the manual). If you'd like to see the whole manual (it's got schematics and I managed to identify what looks like an EEPROM - an M24C02) I'll have to send it privately because I noticed Sony automatically stamps our ID into the PDF and I don't want to get in any trouble....just in case...
          That said, thank Budm: I came across that one myself but wasn't sure it's the same one the manual describes - it doesn't mention its name explicitly, but looking at the link, it's something "MSFRM...something" which seems to match what you linked to, so I'm hoping it's not something dedicated for service purposes, not available to the public...only one way to find out and that's to try it out. Thing is the TV has a bit of "life" left in it even in this state, so the last thing I want is to brick it for good...the client would probably be understanding, but everyone besides him wouldn't - the competition is very fierce here
          I say we start off from the most simple to the most complicated fixes: try a simple reset > try a software upgrade > try to reprogram stuff off-board....if it's the large flash chip in the CI cradle on the right that's going to be a problem, as not only have I never soldered anything that large, but we also might not have anything to write back TO it...
          Oh, did I mention I don't have a memory stick ?
          Wattevah...
          • CapLeaker
            Leaking Member
            • 8352
            there has to be another flash of some sort besides this 24c02, to load the firmware. Because this IC is very small in memory. We are taking 2kbits here.
            • ducky29
              • Dec 2015
              • 369
              • Europe
              Actually there is a way how to factory reset the tv.
              Enter service menu and then press 08
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                Yes, there is: I mentioned it in my previous post. It's the one within the CI slot - at least that's what it looks like in the picture. It's the one I said would be impossible to recover (unless ripped from another TV at which point I'd just swap the boards since they HAVE to be identical for this to work anyway and sometimes even that's not enough with Sonys - the firmware has to match to get a picture)
                Wattevah...
                • CapLeaker
                  Leaking Member
                  • 8352
                  impossible to recover? Why? Folks swapping them no problem. Take is off, read it, erase it, blank check, see if that chip is faulty, program chip with, put it back in it's place. You can find dumps on the internet, maybe ask...
                  I've taken these out before, read it, reprogrammed it and put it back in. It isn't bad.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Well, "impossible" in my case, although I do consider myself to have above-average soldering and electronic skills so I should be able to tackle it. There's a couple of hurdles: removing the IC (haven't done it before) because, and this is the second hurdle, I haven't owned a flash programmer for those large flash ICs - I've only done small SPI and EEPROM ones. Another issue is the risk you're running to break the thing for good, though highly unlikely. And last by not least we've got the issue of this old geezer of a "colleague" looking over my shoulder and basically scrutinizing my every move...I CANNOT work like that so I usually say f-it, which is not the mark of a good repairman, I know...until I somehow get rid of him, it's going to be like this I'm afraid...patience patience patience...
                    Wattevah...
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      Guess what: there's no card slot I suppose you're supposed to use a "jig" that plugs into the only available slot which looks like where a FFC would go...soooo....yeah
                      EDIT: it does - it's under the CI slot, but was hidden by that dummy tray FAIL !
                      EDIT2: I punched 08 in the "TT" menu and it reset the TV. The vertical line is gone but it doesn't tune DIGITAL channels. It grabbed some analog ones but no digital ones and it doesn't let me select "digital setup" (or something like that) in the menu...still a software bug I'd say.
                      Wattevah...
                      • ducky29
                        • Dec 2015
                        • 369
                        • Europe
                        Replace main board.
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          Just out of curiosity - here's the main board....blurry AF I know Is this a tuner issue or a decoder issue ? The Digital decoder seems to be a separate chip on the board according to the manual. If that's toast, no amount of firmware will help.
                          EDIT: just got hold of a memory stick and tried the upgrade procedure: the TV just stays there with a blank screen and no LEDs...still waiting for it to do something. Sure hope it's not bricked at this point...that would be a fuckin' disaster...
                          Wattevah...
                          • CapLeaker
                            Leaking Member
                            • 8352
                            does the analog tuner work to start with?
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              • Romania
                              Yes it does and thankfully it also didn't brick - unplugged it and plugged it back in and it sort-of reset, displaying the "first time setup" screen. Still no digital reception though and I'm sometimes having a hard time getting it to tune analog also - the menu disappears when I hit OK and doesn't take my "start scan" command...something's f-ed up there....
                              Worth noting: before punching "08" in the TT service menu which is the command for reset, I punched 88 instead which the manual identifies as "Digital shipping conditions (Clear tune database)". Interestingly, I came across another forum thread somewhere where a chap messed with this 88 command and subsequently he had no digital reception either, though when I got the TV it didn't pick up anything to begin with, so it was probably not my fault - bad memory blocks is what I'm thinking. There's a bunch of different settings there, but I don't dare going back in there again because I just managed to get it to pick up some analog channels and want to return it as such. At least the stripe is gone so it wasn't all in vain, though if anyone still has any ideas I'd be willing to hear them out.
                              Also worth noting: the card I used wasn't mine - I borrowed it from a co-worker who told me not to format it or delete any of the hidden files from it because it was formatted inside a Sony camera for precisely the purpose of flashing TVs (which apparently is the same as using the tool which TVs "like"), so I used it "as such". It was blank indeed, except for two hidden files...don't know if it had an effect though or if it would've done the same if I had formatted with the tool you guys suggested.
                              Wattevah...
                              • R_J
                                • 9624
                                Is everything correct in the TT OSD Label screen for this model
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  Well damn, I don't remember what it showed there....a bunch of letters and numbers and dashes, but can't remember any of it unfortunately...might fire up TT again tomorrow.
                                  Wattevah...
                                  • R_J
                                    • 9624
                                    If you look in the manual (page 13) it shows what those letters mean, Its the page after the TT MODES table
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      I see D/A mode there: "D is shown when Digital mode is enabled; A is shown when Analogue mode is enabled. Changed by TT53." What DOES digital/analogue mode signify ? Should there's be an option for BOTH ? Or perhaps it's not referring to the "analog/digital" channels at all.
                                      Another issue is that some of the info is cryptic, like ECS or CBA mode...what does that mean ? From the little info I was able to find, ECS refers to the service port hidden on the back.
                                      Wattevah...
                                      • rex98
                                        HP DMI Tool
                                        by rex98
                                        HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                        DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                        The DMI Tool given here are for personal use only.
                                        DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                        You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                        from it, and that you please credit the author...
                                        07-02-2025, 05:51 AM
                                      • Carlos#2003%
                                        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                        by Carlos#2003%
                                        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                        02-15-2024, 07:52 PM
                                      • dkneyle
                                        Sony KDL-46HX850 Can't upgrade/update firmware
                                        by dkneyle
                                        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                        09-25-2024, 10:44 PM
                                        Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                        This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-06-2024, 05:27 AM
                                      • ezenia
                                        PS4 controller left stick potentiometer replacement issue
                                        by ezenia
                                        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                        09-30-2023, 02:19 PM
