Samsung LN 40D630 TV - No Power
  • jason123
    • Oct 2015
    • 1068
    Re: Samsung LN 40D630 TV - No Power
    Any thoughts on this folks?? Would the IC replacement resolve the problem? Any schematic someone could share so I can figure out what the bad part is?? Thanks!
    • CapLeaker
      Leaking Member
      • 8158
      what is written on that IC?
      • jason123
        • Oct 2015
        • 1068
        Originally posted by jason123
        Ok, got the better scope, and the part number is STR W6052S
        Looks like datasheet is:
        https://cdn.badcaps-static.com/pdfs/...d55e88614f.pdf
        I am not getting any voltages on any of the pins. No VCC voltage
        Hi CapLeaker - it's the STR W6052S
          So the new fuse did blow, so you need to verify for sure that resistor RM811 is still good or not and then replace the IC.
          • jason123
            • Oct 2015
            • 1068
            So got the new IC today.. installed it, replaced the fuse, double checked the value of RM811.. upon applying power violent sparking took place in the hot side from component MI802S. See photos.
              • 12196
              • U.S.
              #26
              Take out fet MI802S and test it?
                So you replaced SMPS IC UM801S mounted on the heatsink for the standby power supply and now you also has blown MOSFET's for the Inverter transformer driver circuit. At this point you may want to get new board.
                • jason123
                  • Oct 2015
                  • 1068
                  Oh i got a new board.. i was hoping to salvage this one but at this point sounds too involved. Thanks
                  • jason123
                    • Oct 2015
                    • 1068
                    The FET has holes in it. .charred
                      • 12196
                      • U.S.
                      #30
                      Hmm, self destructed or something else blew it?
                      • jason123
                        • Oct 2015
                        • 1068
                        it's got to be something else shorted or .. who knows
                        • C152Heavy
                          by C152Heavy
                          Summary for TL-DR readers:
                          • VCC pin (18) of PFC...
                          01-11-2023, 02:53 PM
                        • Destroyer-Br
                          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                          by Destroyer-Br
                          I'm working on an Acer Nitro 5 unit with the following specs:
                          • Motherboard: LA-J871P Rev: 1B
                          • Model: Acer AN515-55-59MT
                          • S/N: NHQ7JAL00403906A973400
                          • SNID: 03902728734
                          Initial Issue
                          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                          04-17-2025, 08:18 PM
                        • Dani_2024
                          by Dani_2024
                          10-28-2024, 05:06 PM
                        • repair-it
                          Need advice testing a samsung power supply board with scope
                          by repair-it
                          I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                          07-12-2025, 11:00 AM
