Samsung Plasma pn60f8500afxza
  • mightywetfoot
    • Jan 2019
    I have a Samsung Plasma pn60f8500afxza that the HDMI stopped working, I have been using the WiFi and Component connections to be able to use it. I felt it was time to try to get it repaired. I saw the posts about replacing the chip to get the HDMI working but I feel my stills are not at that level. I ordered a replacement main board (Bn94-06205b) that was stated to be New from Ebay. After installed the new board I am getting the 5 blink codes from the board and the screen does not energize. I installed the old board and the TV starts right up. I tried to load Firmware from USB but after it blinks for a moment accessing the USB it the USB just stays lit and stops flash. Let is sit for an hour and no change. Any ideas on this new board what could be going on?
    The Original board has the bardcode sticker on it
    https://ibb.co/VYdLNmg
  • R_J
    • Jun 2012
    • 9588
    Re: Samsung Plasma pn60f8500afxza
    You need to match the numbers on the white sticker, the board you received could be bad or is for a different panel.
    If the sticker is missing who knows what its from, and what it's for.
    • mightywetfoot
      • Jan 2019
      Okay thanks, I will see if I can go back and sort it out with the seller.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • ohren
        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
        by ohren
        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
        The models launched in 2018 and 2019 respectively....
        09-08-2023, 05:24 PM
      • C152Heavy
        Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
        by C152Heavy
        Summary for TL-DR readers:
        • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
        • Have obtained Samsung schematic & service documents - Can upload if helpful.
        • Have read ALL applicable threads
        • C1818 and CP820 replaced as low hanging fruit
        • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
        • VCC pin (18) of PFC...
        01-11-2023, 02:53 PM
        09-07-2024, 05:50 AM
      • Nicktronic
        Samsung Power Supply Board BN44-00874F
        by Nicktronic
        Hey everyone,
        This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
        Anybody...
        03-17-2025, 06:20 AM
