Vizio m65-D0 help
  • nomoresonys
    • 12276
    • U.S.
    Re: Vizio m65-D0 help
    Originally posted by ecking767
    Yes, the image isn't clear enough to read the IC U32, that will be my guess. most likely that the NAND memory
    Double click the image, it's large and crystal clear.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8326
      Maybe this is the board in question/debate. https://www.ebay.com/itm/LG-55-55LN5...QwH:rk:17:pf:0
      Yes, that is similar to mine. Around the main IC from left to right, there are 3 RAM chips (2GB+ two 4GB) and the last one is a small bga153 eMMC. No other little eeprom or spi flash on that board.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8326
        I can't read U32 either, but that is where I put my bet on and is probably the same idea as my LG board. No SPI and everything is saved on that lil thing.
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • JDC
          by JDC
          ONN 100012588
          Long answer:
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
