JVC LT-40C540 Image jitter + firmware
  • CuriousJohn
    Ordained
    • Dec 2018
    • 134
    • Great Britain
    Hi all, this is my first proper post so here goes.
    I obtained this big store rip off Vestel item last week as not working being stuck with power light on and no other activity. PSU checked out so Replaced the Eprom which brought it back to life but the image appears to be very slightly jumping up and down, the JVC boot logo jumps to so not an external source issue, from a distance looks a bit ghosty not easy on the eye at all possibly a refresh rate issue? Have inspected lvds cable and seems ok, would tcon cause such a fault?
    The eprom I bought for it was stated to have firmware for slightly diff panel a samsung 10 bit "SC400HN01", I was told it should work ok as others had had no issues.
    http://panelone.net/en/40-inch/SAMSU...inch-datasheet
    only difference i can determine between panels is the colour depth, this panel is a 8 bit Samsung "SC400HM01"
    http://panelone.net/en/SAMSUNG_LSC40...inch-datasheet
    I cannot locate a factory menu procedure for this tv, do these sets have a service menu at all as i feel the error lies within the firmware but not entirely sure tbh.
    Does anyone have firmwares for these as i didnt have kit to rip a copy before installing eprom? would like to try re install from usb...
  • nomoresonys
    • 12276
    • U.S.
    Re: JVC LT-40C540 Image jitter + firmware
    Try pressing information and muting keys at the same time.
    • nomoresonys
      • 12276
      • U.S.
      Might say something like LVDS map, might clear it up but usually the picture will have big time distortion when those settings are off.
      • CuriousJohn
        Ordained
        • Dec 2018
        • 134
        • Great Britain
        Hi and thanks for suggestion, have just tried with set off and on pressing both remote mute and i button together but no joy.. :-(
        • nomoresonys
          • 12276
          • U.S.
          Don't know about getting the firmware, found this, maybe they want you to sign up and get a password or some such, not sure. http://pro.jvc.com/prof/support/cdrw_firmware.jsp
          • nomoresonys
            • 12276
            • U.S.
            Maybe: menu/menu/8/select. Be very careful in the service menu, make note of any setting you change so you can change them back if needed, steer clear of aging mode, easy to get stuck on that one.
            • CuriousJohn
              Ordained
              • Dec 2018
              • 134
              • Great Britain
              This set just has JVC logo on it under license by a well known UK electrical retailer, JVC not really involved other than harming there own reputation IMO.
              • nomoresonys
                • 12276
                • U.S.
                I hear that, it's strange, I only see one tv firmware update on their site for a dvd/tv combo.
                • nomoresonys
                  • 12276
                  • U.S.
                  Maybe this:
                  Press the {MENU} button and go to the User Menu screen, make sure
                  that the indicator (arrow) is pointed and highlights the "Picture Control".
                  - The buttons on top of the remote are set to TV & VCR respectively.
                  - Set sleep timer to "0" minutes and while it is displayed, simultaneously
                  press the {VIDEO STATUS} & {DISPLAY} buttons.
                  - The main service menu will be displayed with choices #1 through #9.
                  - Press one of the corresponding number keys to enter that menu.
                  - Use the {CH+} {CH-} buttons to navigate within a menu.
                  - Use the {VOL+} {VOL-} buttons to change the values.
                  - Use the {MUTING} button to memorize the changed value.
                  - Use the {BACK} button to exit the service menu.
                  • nomoresonys
                    • 12276
                    • U.S.
                    I have an LT model but can't remember if I've been in the service menu but the last post seems like the one I may have used if I did, been quite a while.
                    • CuriousJohn
                      Ordained
                      • Dec 2018
                      • 134
                      • Great Britain
                      Hmmm
                      None of it works been through it all over last few weeks. Its time to fix this by getting the firmware and making them available im looking for MB to rip firmware from if anybody has a board from a smash screen set, note panel type and upload it or send it to me and I will am willing to test em all dont like loose ends lol
                      • nomoresonys
                        • 12276
                        • U.S.
                        Could try contact jvc, tell them you need firmware, works sometimes.
                        • nomoresonys
                          • 12276
                          • U.S.
                          Found this phone number, might work. UK Call Centre on
                          0344 561 1234
                          • ducky29
                            • Dec 2015
                            • 369
                            • Europe
                            Source 2580 is the service menu for this model. Its a chinese chassis btw and not vestel.
                            • CuriousJohn
                              Ordained
                              • Dec 2018
                              • 134
                              • Great Britain
                              Thankyou very much ducky29, despite the lack of a source button on remote it worked with input 2580!
                              Hopefully there will be something in there to fix the jitter
                              • CuriousJohn
                                Ordained
                                • Dec 2018
                                • 134
                                • Great Britain
                                Yay jitter gone perfectly crisp image now by changing LVDS enable setting from 1 to 0 it was that simple!
                                Thankyou again ducky29
                                • ducky29
                                  • Dec 2015
                                  • 369
                                  • Europe
                                  You are welcome.
                                  Out of curiosity did you buy the eeprom on ebay from microtech?
                                  • nomoresonys
                                    • 12276
                                    • U.S.
                                    Ahh ok, so not a vestel, good to know that eeprom will work with these tvs with that lvds adjustment.
                                    • CuriousJohn
                                      Ordained
                                      • Dec 2018
                                      • 134
                                      • Great Britain
                                      You are welcome.
                                      Yeah, handy he has them pre flashed cos cant find that fw elsewhere though the Russians are handy and with more time might have found a ripped rusky copy, comrad.
                                      • ducky29
                                        • Dec 2015
                                        • 369
                                        • Europe
                                        Mo is a great guy and very reliable.
                                        • pp74
                                          Marantz NR1508 USB firmware update image
                                          by pp74
                                          Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
                                          Regards
                                          05-10-2025, 11:55 PM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • frankusb
                                          Marantz SR5007 USB firmware update image
                                          by frankusb
                                          Does anyone happen to have the latest firmware for the SR5007? Marantz took their update server down and customer support refuses to provide the image to flash over USB. They offered to let me pay a service center to do the update (has to be over USB).
                                          Thanks.
                                          02-20-2024, 11:29 AM
                                        • TheUser
                                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                          by TheUser
                                          Hello to everyone ,
                                          This is my first post here, and i would like to share with you a small story in case you can help me.
                                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                          02-10-2024, 02:07 PM
                                        • zklgfs
                                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                          by zklgfs
                                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                          08-11-2025, 02:14 PM
