Samsung UN60FH6200F TV - No backlight - Please help
  • Snipeye
    • Jul 2018
    • 9
    Re: Samsung UN60FH6200F TV - No backlight - Please help
    Good news - I figured it out! There were three resistors blown on the back side of the board, near where the LEDs plug in. They were, from the shopjimmy picture, supposed to be 3R00 resistors, in parallel, and I'm guessing they were just acting as a fuse. I measured one at 16Mohm after desoldering it, and guessing that that was the problem, shoved a beefy 1.5ohm resistor in their place. Worked like a charm.
    (Note that I will not mention the brief moment there was a 47 ohm resistor there to see if it worked... and the blue smoke it released).
    • Snipeye
      • Jul 2018
      • 9
      @budm, I was getting ~400v IIRC.
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        Those are current sense resistors if I'm not mistaken, by your description. They're paralleled to drop the resistance quite low so they don't have too much voltage drop across them. I've never seen a TV where those resistors were faulty, but I guess there's a first time for everything...
        Wattevah...
          Since the current sensing resistors went open circuit, that is why you are getting 400V.
          • emmy1
            • Jun 2019
            • Rwanda
            what are the values of the 3 resistors on the back near the connector that are in parallel (R9151-R9153) mine are burned
            • R_J
              • Jun 2012
              • 9608
              All 3 are marked as 3R00 which are 3Ω each
              • jasonkhonlaw
                • Feb 2022
                I know this is SUPER old, but can you tell me what power rating the 1.5ohm resistor you used had on it? My power board has the same exact issue. Thanks!
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  #28
                  Power can be determined by their size, though it never hurts to go bigger if unsure.
                  Wattevah...
                    09-07-2024, 05:50 AM
                  • sansanpartida
                    Samsung QE82Q70RAT no backlight
                    by sansanpartida
                    Hi everyone!
                    Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                    My issue: No backlight.
                    Model: QE82Q70RAT
                    Type No: QE82Q70RAT
                    The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                    So hopefully, I can fix this cheaper.
                    05-22-2024, 06:56 AM
                  • howardc64
                    Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                    by howardc64
                    TV was fixed just after removing Samsung's rear snap cover.
                    This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                    Maybe PSU->backlight connector didn't have a good contact?...
                    07-23-2025, 12:34 AM
                  • howardc64
                    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                    by howardc64
                    • Prior owner tried a replacement main board. No difference.
                    • Samsung 2x red blinking standby LED = panel fault
                    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                    07-19-2025, 10:54 PM
                  • Ierwin
                    by Ierwin
                    05-13-2025, 03:31 PM
