Samsung UN40H5203 Flashing Backlight
  • jason123
    • Oct 2015
    • 1083
    Re: Samsung UN40H5203 Flashing Backlight
    So my first step was to replace LEDS. Once i did, i tested with original power supply. They turned on blinking very bright. Got a new ps board. It did the same thing but i left the strings connected too ling while i was attempting to take measurements... eventually most leds shorted opened again...unfortunately unsalvageable at this point .. none related quick opinion.. up for sale for $20 is a samsung 50" 4k tv... any guess if this issue is fixable (color line and color bleeding on top)
      • 12269
      • U.S.
      Could be panel problem, sometimes it's hard to tell.
        Bad panel.
        • jason123
          • Oct 2015
          • 1083
          Thank you guys!
          • learnmore
            Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
            by learnmore
            Hello Community!
            CASE DETAILS
            Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
            13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
            Tried inserting firmware on USB and left it in for a few hours, but no change
            03-03-2024, 09:49 AM
            09-07-2024, 05:50 AM
          • C152Heavy
            by C152Heavy
            Summary for TL-DR readers:
            • VCC pin (18) of PFC...
            01-11-2023, 02:53 PM
          • ohren
            Samsung ue55nu7096u - no backlight - faulty LEDs?
            by ohren
            I'm looking at a Samsung model ue55nu7096u that I've only ever seen in a non-working condition, i.e. I don't know if the failure was progressive or instant.
            Symptoms
            No backlight at all — LCD and logic board are working normally. Resetting all settings and installing system updates has no effect.
            I tried reseating the connectors between PS and logic board, and PS and panel. No difference there.
            I could not find a service manual.
            Measurements when powered on
            Bulk cap: 388 V. Stable....
            04-04-2022, 02:58 PM
          • sansanpartida
            Samsung QE82Q70RAT no backlight
            by sansanpartida
            Hi everyone!
            Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
            My issue: No backlight.
            Model: QE82Q70RAT
            Type No: QE82Q70RAT
            The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
            So hopefully, I can fix this cheaper.
            05-22-2024, 06:56 AM
