Sasmung la40m81bd - Recapped
    • 12306
    • U.S.
    #41
    Re: Sasmung la40m81bd - Recapped
    This one matches first 9 numbers? https://www.ebay.co.uk/itm/272695645973
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      #42
      That's cheap...I'd say there's nothing to lose by getting it. If anything, you'll have it as a spare. This is what I used to do back at my old shop: when I wasn't sure which part was faulty, if it wasn't terribly expensive, I'd buy it and keep it as a spare if it turned out that wasn't the issue...ah the good ol' days when I was virtually running my own shop....none of this corporate sh!t where nobody cares about you and you're basically left unscrewing flat heads with philips...>_>
      Wattevah...
        • 12306
        • U.S.
        #43
        Whole page to look thru, might be a match somewhere, if those 2 don't work? https://picclick.co.uk/Tcon-Board-40...987820813.html
        • Amraks
          • Nov 2011
          • 725
          https://www.aliexpress.com/item/free...6-7aa4934d380a
          Found one cheaper and don't mind the 4 week wait.
          I could only try a new tcon and go from there I guess.
          • Amraks
            • Nov 2011
            • 725
            New T-con showed up today shipping was pretty fast.
            The result wasn't what we was hoping for still got the same picture error.
            So problem would be on mainboard wouldn't it?
            • angelos
              • Dec 2012
              • 573
              • South Africa
              #46
              Hi Amraks, i have never seen your youtube video because of it being blocked here at work but sometimes the bonding tabs cause weird issues. I hope its not that in your case otherwise you're stuck with a scrap tv.
              • Amraks
                • Nov 2011
                • 725
                Pretty sure this isn't a tab bond issue.
                Have been reading about ic1803 going bad after bad caps
                This here is from a bulletin from Samsung about this tv
                Symptoms
                HTML Code:
                  No Power, Keeps clicking, Clours incorrect, No DTV / ATV, No DTV or RF signal on TV.
                  SMPS capacitor failure causing No power or No DTV to above models.
                  This is due to EEprom value in Factory setting change when SMPS failure (side effect
                Solution
                HTML Code:
                 Product :
                LCD TV
                Bulletin No.  : 10-LCD_TV-A003
                 Model   :
                LA 40/46/52 M81BDX/XSA
                Bulletin D 24 Apr 2010
                LA40/46 N81BDX/XSA
                Buyer    SEAU
                LA32/40 R81BDX/XSA
                LA32/40/46 S81BDX/XSA
                LA40/46/52 F81BDX/XSA
                Subject  :
                SMPS failure due to SamHwa Cap causing MAIN BOARD EEPROM setting change
                  This is due to EEprom value in Factory setting change when SMPS failure (side effect)
                [Step1]
                 Replace Capacitors which bloated from SMPS (Refer Table below) & perform data adjustment in [Step 4]
                        ** If still fails to power on and keeps clicking refer steps 2, 3 & 4:
                [Step2]
                  Replace Eprom IC1803 (8 Pin surface Mount IC)
                        ** Once power on for 1st time after Eprom replacement TV will click on / off 3 times then picture will illumina
                te
                [Step3]
                  Access Service Mode – Press the following
                        ** TV in off state then on remote press INFO – MENU – MUTE – POWER ON
                [Step4]
                 Perform Data Adjustment in SVC Mode (2.Option table & 8.Adjust menu, refer following pages)
                  • 12306
                  • U.S.
                  #48
                  Definitely worth a try, can you find the eeprom? not sure if this eeprom needs to be pre-programed???
                    • 12306
                    • U.S.
                    #49
                    One guy used this one: https://au.element14.com/microchip/a...oic/dp/1972001
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      #50
                      Video's been removed probably since I can't access it either....
                      Wattevah...
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #51
                        I have repaired a couple of older samsungs once i have replaced all the bad caps i then replace the eeprom with a blank new one once the sets starts up usually a few attempts the tvs have been fine i guess the set somehow re writes its own eeprom data back too the new ic
                        • Diah
                          • Feb 2013
                          • 6460
                          +1
                          especially when the firmware contain the eeprom bin. which any TV able to downgrade its firmware had this section and can be noticed that the TV start downgrade or upgrade its start twice
                          • Amraks
                            • Nov 2011
                            • 725
                            Ignore the first video it had kids screaming in backgroup
                            Heres the video I took once I had it in my hands.
                            https://www.youtube.com/watch?v=d3zC...ature=youtu.be
                            • Amraks
                              • Nov 2011
                              • 725
                              I ended up pulling off the chip and erasing it.
                              now the tv is switching on and off every 2(roughly) mins still have the fuzz pattern.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #55
                                my guess would be a mainboard issue what mainboard is used in this set
                                • Amraks
                                  • Nov 2011
                                  • 725
                                  Mainboard is BN41-00888B
                                  Given that I have this new fault would mean the eeprom chips data isn't getting written.
                                  • Amraks
                                    • Nov 2011
                                    • 725
                                    well I took the chip off the board and read the chip there is data being written but still getting this new fault so would it be safe to say this chip faulty and getting corrupted.
                                    • Dannyx
                                      CertifiedAxhole
                                      • Aug 2016
                                      • 3912
                                      • Romania
                                      #58
                                      You could try replacing it, though I believe at this point it's a main board issue and should replace that instead.
                                      Wattevah...
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #59
                                        looking at your photos in post one it looks like your mainboard is a BN94-01200B (on white sticker) although i cant seem too find any for sale maybe you could look on shop jimmy and see if you can use another mainboad
                                        • Diah
                                          • Feb 2013
                                          • 6460
                                          how about you write to us the chip No you erased ?
                                          did you flashed firmware after erase ?
                                          did you logged in Service menu and from there you reset the TV ?
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
