Panasonic tx-p42st33e
  • saud52
    • Aug 2015
    • 24
    • Bosnia and Herzegowina
    Dear colleagues, I need your help!
    On the repair I have plasma TV Panasonic with GPF14de chassis. In the TNPA5390 network several components were burnt, tags can not be read. I have a schema but an Panasonic schemes have no component tags but only Panasonic code numbers. I need tags of these components: FET Transistor: B1CERR000055, smd Transistor: B1CHND000004, and small glass diode : B0BA02400030.
    Does anyone know this? Can you help me?
    Thank you in advance!
    Saud
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Panasonic tx-p42st33e
    Panasonic R6015ANX B1CERR000055 Transiostor TO-220
    Cant find the rest , need pictures of the board.
    • saud52
      • Aug 2015
      • 24
      Saud
      Thank you for the answer, here I am sending you a schematic diagram
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Need a picture of the burned board/area. I got a few of these powersupply's so i can look what the partnumbers are. The B1CE etc is for panasonic...
        • saud52
          • Aug 2015
          • 24
          Thanks! I need tags of these components: small glass diode D300/D301= B0AACK000004
          • Andre Gilbert
            by Andre Gilbert
            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
            11-20-2024, 08:52 PM
          • Dannyx
            Panasonic SU-HTB18 dead power supply (unidentified transistor)
            by Dannyx
            Good day folks. I had a look at this soundbar from Panasonic today and it seemed like an easy enough fix, but then I got stuck.
            Have a look at that fried primary. I reckon the transistor popped and took out the current sense resistors with it before the fuse could open to cut the power. I thought I'd have a hard time figuring out what values those are, as it usually happens when SMD resistors go up in smoke, but thankfully I was able to clean them enough to read 1r60 on there, which is 1.6ohms, so that was sorted - we need 8 of those.
            On to the transistor: it's one...
            01-23-2021, 10:33 AM
          • AquaMan Ua
            by AquaMan Ua
            05-17-2025, 09:40 AM
          • magneh
            Behringer Eurolive B205D repair - help identifying transistor
            by magneh
            Hello
            Got this speaker from a friend , defective. Power led comes on and off , in a loop.
            Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
            After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
            I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
            Still, I need to replace this transistor....
            06-18-2025, 02:34 AM
          • elsomer
            help to identify transistor msi ms-15ck1
            by elsomer
            hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
            02-17-2025, 05:30 PM
