Lg49uj6200ua
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Re: Lg49uj6200ua
    I will try removing wifi module. I never lose backlight. What I lose is video signal processing. I will also try with ethernet connected if it has a port.
    • budwich
      • Jul 2015
      • 3097
      Re: Lg49uj6200ua
      Have you tried a "non-hdmi" input... ie. component / composite video? just wandering about hdcp "issues" choking things.
      Since you appear to lose the remote, sounds like either its pairing is gone or the main board is "tied up" doing something and can't respond.
      Can you clarify what you are seeing on the screen when you say "PIP". Is it more likely "split screen" with one half a picture, the other half is supposed to be the menu / operating system screen.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Re: Lg49uj6200ua
        On the left half of the screen there is a field "select input"
        When you choose an input, if there is active signal on it, it displays it in a small PIP style window with video and audio. Right half of the screen remains the Menu selection Screen. This is why I still think it is the CPU. I tried disconnecting the wifi module with no success.
        Yes, I tried the antenna input from my off air antenna.
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          Re: Lg49uj6200ua
          Also note that this unit will detect the flash drive that is properly formatted with proper folder name and file name on it but will not ask if I want to upgrade? Board that would go into input selection menu did recognize drive and take update.
          • budwich
            • Jul 2015
            • 3097
            Re: Lg49uj6200ua
            As with some / most makers, they do a "version check" and won't continue with the process if the version on the drive is the same or less. Of course, if for what ever reason your firmware in the set has an actual problem ("dropped bits"), this technique doesn't allow one to get around the problem with the "simple usb" reload. :-(
            Have you tried a "serial control input" which I have seen in my travels?
            Further: you didn't mention much about the remote, if you are using one and / or have another. Is the power button on the set a "toggle" type, it appears to be in the generic user guide. LG certainly has "limited" documentaiton.... :-(
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              Re: Lg49uj6200ua
              I am using the original remote. This set has a single push button on the bottom rail.
              I will explore "serial control input"
              LJ
              • budwich
                • Jul 2015
                • 3097
                Re: Lg49uj6200ua
                one more thing about the "single button" thing... the question is "does it toggle". On samsung, there is a single button but it has "toggle action"... meaning the button can "move" like a "toggle" to select different operations on the menu. This can be done without the remote.
                You indicated that you might replace the smaller "side board" from the main... have you done that? have you tried powering up the set and then disconnecting that board from the system?
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  Re: Lg49uj6200ua
                  I will check and see if in fact that button does toggle. I know exactly what you mean. This button even says PUSH on it. No I have not tried with it disconnected because if disconnected neither the button nor the IR will be able to communicate with the main board. Board is in transit to me. Will advise when I get it.
                  Thanks for all of your help. Happy New Year!
                  LJ
                  • budwich
                    • Jul 2015
                    • 3097
                    Re: Lg49uj6200ua
                    Not sure that the board is the interface as I believe that the remote is "bluetooth" or equivalent as opposed to IR... I think as there is "pairing".... although I do see mention of a "standard remote" so probably also has an IR interface.
                    • budwich
                      • Jul 2015
                      • 3097
                      Re: Lg49uj6200ua
                      Another question... back to your testing on the led inv outputs. You provided voltage measurements for the + side to ground but didn't provide the same for the - side. Are you still seeing a standby flash of 3?
                      • ljintexas
                        LJinTexas
                        • Jan 2015
                        • 669
                        Re: Lg49uj6200ua
                        Button does not toggle, straight push. Interface board made no difference. I can measure Inv voltage from - to chassis. I will measure both during setup screen before it pukes and then after it pukes. Backlight never wavers after fire up. I noticed a white flash on right side of screen when it pukes.
                        LG offers the main board but only as rebuilt and has a stiff core charge of $75. They know there is an issue. My CPU guru that has a BGA station says no parts available.
                        CRB37647501 is part #...$177 with $79 core if you don't have an exchange.
                          • 12146
                          • U.S.
                          #72
                          Re: Lg49uj6200ua
                          Looks like these tvs are suppose to toggle, check that owners manual there. https://www.lg.com/us/support-product/lg-49UJ6200
                          • ljintexas
                            LJinTexas
                            • Jan 2015
                            • 669
                            Re: Lg49uj6200ua
                            I will try disconnecting the button and see where that leads. I can tell you that the one board that did process video in the pip INPUT SELECT mode actually put button instructions on the screen. Like press and hold for input selection, and it worked by just pushing it.
                            LJ
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • smic717394
                              by smic717394
                              07-25-2024, 10:16 AM
                            • hervou
                              Philips PSU (715G7350-P01-000-002S) behaving funny
                              by hervou
                              I'm becoming crazy trying to fix the Philips TV of my old man (model 43PUS6201/12 - the TV, not my dad). I've read again and again discussions about this and similar TV models, on badcaps (thanks so much !). I see no other option than asking for your help.
                              The symptom is simple : when I plug the power cord, the red "stand-by" LED does not light on anymore, and the TV powers-on neither with the remote control nor with the rear button. I guess at this point you immediately think at the 5V (or other voltage depending on the hardware) stand-by output......
                              04-20-2024, 02:56 PM
                            • Chrissygizmo
                              by Chrissygizmo
                              02-10-2025, 12:33 AM
                            • stylishconsultant
                              un60j620dafxza - Samsung No Display Problem
                              by stylishconsultant
                              Hi All,
                              Need help.
                              I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                              So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                              problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                              might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                              09-04-2024, 03:26 AM
