SONY KDL-32BX300 fault help
  • ivtec
    • Dec 2008
    • 1967
    Hi guys:my friend brought me this Sony KDL 32BX300 and this fault seems to a Synchro fault see video the sound is not from the tv .
    https://www.youtube.com/watch?v=pZ85...ature=youtu.be
  • ivtec
    • Dec 2008
    • 1967
    Re: SONY KDL-32BX300 fault help
    Hi guys you have not even a clue?,i opened it up and don't see any bad caps,i checked the converter board caps and all good ,this is a sync issue in old tubes that was the vertical IC on this ones have no idea
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      I have never seen that fault before. if this was my set i was working on i would try a mainboard swap if its a reasonable price.
      • ivtec
        • Dec 2008
        • 1967
        Thanks bro i have the board out and will check it out ,about getting another board,there are none cheap,the cheapest is 45 bucks and out of stock,will look in my scrap, maybe i have any who knows,i have a lot of boards,will see,thanks
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          im not sure if its possible a firmware fault could cause this? does heating or freezing the mainboard change what your seeing on the screen
          • nomoresonys
            • 12086
            • U.S.
            Hard to tell, I would try a firmware update/reapply, if for nothing else just to rule it out.
            • ivtec
              • Dec 2008
              • 1967
              Hi guys update about Sony KDL-32BX300,i took out main board and went through all caps and did not find none bad,so i put board in place and turned tv on and tv doesn't have the sync issue no more it works fine on all inputs ,go figure,
              • nomoresonys
                • 12086
                • U.S.
                May have just been a loose connection.
                • ivtec
                  • Dec 2008
                  • 1967
                  hope so,been working for a couple hours so far so good.
                    May be board mounting screws are not tight so it get bad ground connections between the boards and the chassis. Keep an eye on them.
                    • ivtec
                      • Dec 2008
                      • 1967
                      Thanks budm ; well i had taken out main board for inspection and put it back so it might had help connections,who knows,it's been working great so far,thanks
                      • sickboy
                        Strange CRT Fault (Sony Trinitron M1410U)
                        by sickboy
                        This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
                        11-10-2024, 05:02 AM
                      • Carlos#2003%
                        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                        by Carlos#2003%
                        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                        02-15-2024, 07:52 PM
                      • dkneyle
                        Sony KDL-46HX850 Can't upgrade/update firmware
                        by dkneyle
                        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                        09-25-2024, 10:44 PM
                        Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                        This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-06-2024, 05:27 AM
                      • sarry86
                        sony dav-dz650 home theatre psu that has fault
                        by sarry86
                        Guys I am in need of your help, I forgot to discharge capacitors and went directly to check for the bad transistor, unfortunately I shorted this pwm ic, I'am not very good at troubleshooting hardware issues, can you guys help me know the similar ic to the ssc6200? It is a sony dav-dz650 home theatre psu that has fault, please help me...
                        12-11-2021, 11:19 AM
