Sony KDL 40v5100
  • douglasfir
    • Oct 2018
    • 6
    Sony KDL 40v5100
    Hey everyone! I have this set here and the symptom is, the set will shut down after about an hour or so, sometimes giving three blinks of the red standby LED. I know what the code is for three blinks, so I went into the service menu, and under diagnostics is an error under DC Alert, nothing else. I have checked extensively for cold solder joints, and for bad caps with an ESR meter. Nothing jumps out at me.
    When the set is running all of the voltages are normal and well within tolerance. When it shuts down, all of the regulators are shut down as well, 12v, 15v, 3.3v stby. Makes it tricky to pin down the cause easily for sure.
    I've yet to find any specific info on this specific model/common failures, etc. I downloaded the service manual, thanks to this forum, which I am looking at now. Does anyone have any pointers for me?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Sony KDL 40v5100
    Will the set switch back on immediately after it shuts down or does it need to cool down first. If so, perhaps you can use freezer spray to isolate the area on the circuit board that will allow it to switch on sooner.
    • AK_777
      Sony KD-65A1 Repair – 4 Red Blinks Error
      by AK_777
      Hi everyone!
      I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
      Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
      02-20-2025, 04:15 PM
    • jchon
      Sony A1e 5-blinks help
      by jchon
      Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
      I found the service manual, which was critical to know where to probe.
      https://www.manualslib.com/manual/20...1e-Series.html
      With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
      Unfortunately the 5-blinks...
      06-28-2023, 11:52 AM
    • Nicktronic
      Sony XBR-65X850D 2 Red Blinks
      by Nicktronic
      I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
      Any Sony experts out there that can help??...
      11-19-2023, 06:51 AM
    • dumbdd
      Sony 75X9400E TV.. 5 Red blinks
      by dumbdd
      I was using this TV for 5 years before it stopped working. I like this TV and would love to fix it myself.*
      When I press the power button, the white led comes on (sony calls the module smart core) and then it switches over to 5 red blinks. No screen, no backlight, no relay click, nothing. I have disassembled the tv and found the service manual for 75x940e online. The manual suggests a faulty power board, TCON or the panel.**
      The standby pin is at 3.3V. Fuses on the mainboard and TCON are fine. Caps on TCON also seem to be fine. When I turn on the tv the white led...
      07-01-2023, 08:54 PM
    • Nicktronic
      Sony XR-55X90J 4 blinks
      by Nicktronic
      Hey guys, got this Sony that turns on momentarily and then goes black with 4 blinks of the standby light. I can't find a service manual, but best guess was the Local Dimming board based on a similar TV saying LD_ERR or BCM_ERR. I found a replacement, but it didn't work. Before I put more money into replacement boards, Im wondering if anybody has seen this issue and what worked for them, or has the service manual for this specific TV.
      Thanks!...
      02-13-2024, 07:01 PM
